A55 Smoothing Plane
sanding disc adhesive
jack
>i made me a disc sander for bowls what type of adhesive do i use to attach the sandpaper to the foam disc where i can easly quickly change the sandpaper is there a spray adhesive that will let me do this
thanks
jack
Re: sanding disc adhesive
Bob Hackett
>3M makes a product just for sanding discs.It works very well.
MB
RevDoug
>I prefer hook and loop. you can change the disk much faster and the mess of glue over spray is totally avoided.
Earl
>You can pick up the "hook" material for a buck at any fabric store and super glue it to the disk. Then any hook and loop sand paper will stick to it and you can easily cycle through all or any of the grits without distroying the sandpaper.
Russ Fairfield
>Franklin TiteBond makes a spreadable adhesive for this purpose.
Hotmelt glue works as well as anything.
>Jack
I prefer hook and loop also but a can of 3m super 77 spray works really well. You can also buy adhesive backed pads.
Bill Hale / The Wood Spinner
>The reason that hook and loop is a better system is due to the ability to reuse the sandpaper. With adhesive it is generally use once and throw away. With hook and loop you can pull off and save untill it is fully used up. It is also a lot faster to pull off and just stick on the next grit.
Good turning and be safe
Bill
>I found either system to be a hassle so I purchased a sanding mandrel for each grit. Now I install the sandpaper and use it until it doesn't cut affectively then replace it. It's made my sanding pads and velcro last almost indefinitely.
