Have a question? Ask Woody!
Thin elm bowl
Thin elm bowl
Thin elm bowl
Larry Hancock; Ardmore, OK
>This bowl is from an elm tree I cut in my pasture. It is turned green and warped then the bottom returned. The diameter at the top is 8" by 8 3/4" and it is 3 3/4" tall. The thickness throughout is about 0.080", a Wally thickness bowl only a bowl is easier to turn thin than a hollowform. The opening is turned toward the heart. The finish is Rockler's Polyurethane Gel, 4 coats. Dave Smith brought some pieces when he came here with this finish on them and I liked the feel the finish gave to the piece.
This piece or any other piece I post is open to critique or comment of any kind so post anything you want. I feel it is for the benefit of the group to have all the information and opinions you can.
Thanks for looking.
Larry
Re: Thin elm bowl
Inside of bowl
>This is the inside view.
Larry
Re: Thin elm bowl
Bottom of elm bowl
>The bottom of the elm bowl.
Larry
Re: Thin elm bowl
Re: Thin elm bowl
Mike Schwing from Maryland
>Beautiful work Larry. I appreciate the attention to the detail on the foot.
As a critique, I would have liked to see two things done a little differently. (not that I could have achieved them on my own) The form looks a little "squashed" to me. Maybe slightly less diameter for the same height might have made it look a bit taller.
I would also raise the foot a bit, I like this piece off the ground so it accentuates the flowing profile.
Beautiful work indeed!
Re: Thin elm bowl
I bid $10
TDaniel
>Just joking:). Nice work Larry.
Re: Thin elm bowl
Re: Thin elm bowl
David Eaves
>Hi Larry,
That is excellent work I really like it. You judged the warping/alignment well too. The shape it has moved to is suits it.
As regards form I echo what Mike has said, it looks a little squashed. I guess the tree dictated your height here.. so I suppose it would have to have been narrower in diameter. It is a good form though, and I still like it a lot. The foot detail finishes it off well.
Cheers
David
Re: Thin elm bowl
Mike and David
>I had to sit this piece aside and look at it for a while before I decided to go ahead and finish it. At first I did not like it at all because something just didn't look right. I've been playing around with shapes a lot lately and will try some variations like you suggest and post them later.
Thanks for the input.
Larry
Re: Thin elm bowl
Brad Vietje
Re: Thin elm bowl
Brad Vietje
>Very nice, Larry !
I'll differ with the other comments; while I like it the way it is, you could make another with a narrower base, and slightly smaller foot, making it look even w-i-d-e-r.
Spalting Elm goes soft pretty fast, and it looks like you got this chunk on the lathe at just the right time -- enough spalting to look great, but not soft and punky. Very nice.
Safe Spinning,
Brad Vietje
Thetford, VT Spring ??? 15 degrees, snowing & windy :(
