HVAC Vacuum Pump
Bernie
>Will a Robinair HVAC style 4 cfm vacuum pump
work for a vacuum set up on a lathe. Can get
one of these pumps reman for 140.00
HVAC Vacuum Pump
Bernie
Re: HVAC Vacuum Pump
John Stegall
>I do not have my Robinair around at the moment but it works just fine and I suspect it is similar to yours.
Bob Lemon Sacramento Ca.
>Bernie, I use one for vacuum clamping of veneers, but, I also create an artificial leak to keep from boiling the glue. If the pump is in good condition, it will pull down to 10 microns of mercury pressure. (This is very close to absolute zero) I do have about a 1" plastic tube that I hook to the discharge line to direct the discharge air out of the building so there is no oil vapor in the room. Bob
>Does it have a sister? or brother for that matter |;-}}
Your source?
Mark
drop the 2 for mail
