Finish Turning a *very* wet piece of cherry
Greg W. in NC
>I have some very wet cherry bowl blanks, with bark attached. This tree was cut within the last couple of weeks, I think. I would like to use quite a few of these blanks for natural edge bowls. My question, how do I do that? Should I rough turn these, and finish later, as usual? Or should I try to finish the bowls as I turn them? I know cherry checks very easily, so I don't want to lose these, or the bark from them.
After seeing Mike Schwing's recent posting, where he finished it 'while wet', it makes me think maybe that's a good way to finish? However, Bill Grumbine also mentioned having rough turned one, and returning it, but unsure whether the bark would stay attached.
I have a customer that wants one in 3 days.....is that even possible? The bowl would go 1/2 way around the world, so there would be virtually no way to repair it, or even replace it should it crack. Thanks for any and all replies!
Re: Finish Turning a *very* wet piece of cherry
Mike Schwing from Maryland
>Please don't use this as the expert opinion, only that of a new turner.
If you want it to be round you'll have to resort to the roughing and then drying, then finish turning method. Fruit woods move a LOT while drying and no cherry bowl turned wet will still be round when it dries. I guess you could PEG it.
If you don't mind a little warp, you can do it the way I did with the bowl pictured here last evening - turn to 1/4" or less, sand while possible on the lathe, and slip it into a couple paper grocery bags for a few weeks till it dries. It might crack, it might not.
Other drying options are available to get it done in 3 days - microwaving, etc.. but its still doubtful it'll be really dry and customer worthy.
>Greg
I've turned several and microwaved them. I'm certainly not an expert on this. I microwave them on low power until they are warm and pull them out and let them completely cool. I continue doing this until the bowl doesn't lose any more weight. I do this half hazard. Anytime I walk upstairs I run it through another cylcle. I usually us dry by the end of the day if not sooner. It does warp so I turn them all natural edge so they look oval anyway. If your really concerned about the bark simply peel or carve it off. Then color the top edge. I burn it with a propane torch.
Three days?...
BubbaBob
>...I'm a big proponant of fart work, but I wouldn't even THINK about three day turnaround....three weeks...maybe...three days...no way.
BubbaBob
John Trant (aka Boxes-n-Bowls)
>I agree with Bubba. Just because your customer wants it in 3 days does not mean that it is a reasonable (or even possible) expectation. Your customer obviously has no appreciation of what is involved in turning so it is your responsibility to educate him. Remember: the end product of a "quick and dirty" process is usually just dirty and the subsequent repairs keep if form being quick.
John
Greg W in NC
>Thanks guys for the input! After playing with this blank again tonight, I've decided to just let it dry in its own time. The heat gun works quite well on the heart wood, I guess because of it's density. However, it wasn't drying the sapwood very well at all, I guess because it is not as dense.
Bubba...."fart work?" ha! Actually.....this 'customer' is a coworker, and a very good friend. He's also bought more from me than any other person, so I wanted to accomodate him if it were possible, but I had already warned him it might not happen...and it's not!
This is the first natural edged cherry bowl I've done, but it won't be the last! Really nice stuff!
Re: Three days?...
Roger F.
>Hey Bubba,
You do have a way with words don't you? Keep up the good work/words. I always get a kick out of your responses, especialy this one.
Roger F.
I meant...
BubbaBob
>...fast, not fart...
BubbaBob`
we liked it better the first post
TDaniel
