REAL MILK PAINT
question on friction polich finish
jim reasoner
>I have used tung oil varnish for bowls for a long time. Now that I have started doing pens I use friction polish on top of sanding sealer. It makes a very nice finish. Question - On larger things like bowls is friction polish practical? I know it has to be applied with the lathe on high speed and with fast constant burnishing with a cloth. I have had the experience of friction polish beading or lining up on a pen without fast constant movement. I am just wondering if a bowl has to much surface to maintain that fast constant burnishing like on a pen. I really do like the sanding sealer-friction polish finish but I am not sure it will owrk on a bowl-anything up to say 12" diameter.
Re: question on friction polich finish
GeeSeaWhy
>I have successfully used friction polish on a few small, burned bowls. It doesn't give the same gloss as it does on items like pens but it does give a higher shine than an oil finish. I use tung oil varnish on most of my bowls and I think you're right - bowls generally have too much surface area for friction polish to cover. If I want more gloss or a film finish I generally use shellac.
Graeme
Re: question on friction polich finish *LINK*
RonZ
>I read this after I posted the above before I read your post. The 9" dish is the largest Item I have done with Mylands high build friction polish. For larger items I use my own blend which is 1/3 shellac flakes, 1/3 alchohol, and 1/3 artists [light] linseed oil. This does dry as fast and can be used on larger items.
Above post.
