Veritas - Innovation in Tools
Stihl 260?
Stihl 260?
Stihl 260?
Ron Sardo in PA
>I just walked next store to check out the chainsaws. It seems the 026 pro has been discontinued but is similar to the 260 pro with a 16" bar. I looked at a 290 (mid-range) and a 310 (pro-range). Both have a 20" bar, but the 290 has a smaller chain, (at least this is what I was told. If anybody could educate me on this please do so.)
All three are only $50 apart so price is not a factor.
260 - $360 - 10.6 lbs - 3.50 hp
290 - $410 - 13.2 lbs - 3.75 hp
310 - $370 - 13.2 lbs - 4.00 hp
I'm leaning towards the 260 - because of the weight. But the 16" bar might be a bit small. What do you think? Will I be sorry with this size bar?
BTW - My Husky has a 28" bar
Re: Stihl 260?
Re: Stihl 260?
Bill Grumbine, Kutztown PA
>Hi Ron
I love my 026. It is nice and light, and cuts all day long. And of course, if I need to do big stuff, I haul out the 046. ;-) If it is a lighter saw you are looking for, the 026 (or the 260 now)definitely fits the bill.
I put a 20" bar on mine, although the dealer I bought it from told me that weightwise it was perfectly blanaced with an 18" bar. I just bought a 16" bar for it because I have a lot of little brush size stuff to cut, and waving that 20" bar around for that stuff is no fun at all. You can buy different size bars for it, although there is a maximum recommended.
Bill
Re: Stihl 260?
Re: Stihl 260?
Bruce McElhaney Spring Lake, MI
>Any Stihl dealer should be able to switch out chain bars for you. I recently purchased a Stihl 250. The dealer had versions with 16" and 18" bars in stock. I bought one with the 18" bar and was glad I did. The 260 is very similar with a slightly larger engine, and slightly heavier. I also looked at the older model 026 Pro and liked it a lot, but it was more $$$.
Re: Stihl 260?
Re: Stihl 260?
Paul Norton
>Ron, the 260 is a great saw and 16" will do a lot of cutting. However, if you are cutting timber for turning, ripsawing is hard on the lighter saws and
more power and a longer bar will be more effective.
Re: Stihl 260?
Re: Stihl 260?
Lyn J. Mangiameli
>I have a 290 and like it a lot. However, if the larger 310 had been available when I got my 290, I would have purchased it, simply for the slight increase in power. In either case, I think these saws are very well balanced with a 20 inch bar.
I pair a 14 inch electric with the 20 inch Stihl. For me, this has been a great combination that satisfies 95 percent of my needs (the other 5 percent of the time I wish I had a bigger Stihl with a 28-32 inch bar).
Re: Stihl 260?
Get a POO-lan
BubbaBob
