General Lathe remote switch
adrien
>Got the following response from General Manufacturing anent a remote for my 26020 VD: It 's a lot more Expensive than I anticipated:
--- General Mfg co ltd wrote:
A remote control will be available in
no more than one month. Price will be
$225.00 Cdn or $180.00 US. Part # 1650.
You can order one now and we will send
it when available. We accept Visa and
Master Card.
Regards,
Christian St-Cyr
Re: General Lathe remote switch
Bill Howatt
>Adrien,
Do you know if this remote has the pot to control the speed as well as the on/off buttons?
Thanks
Bill
adrien
>That's all the information Christian St-Cyr sent. I did request more details and a brochure, but all I got in response was
Good morning,
We have done many testings, with
many remote controls. The one
we offer is considered by our
experts as the best one to use
with the lathe.
Of course, you could get a less
expensive one from your side...
Best Regards,
Christian St-Cyr
Re: General Lathe remote switch *LINK*
Jean Michel
>Hi Adrien,
If all you need is the remote On/Off switch like I wanted and made for my General 26020VD when I had it, it is easy and dirt cheap to do... No high voltages are touched, safe to do with a minimum of electronic knowledge... I made it for far less than 10$ and 10$CAN that is!
The wiring is done in the side On/Off switch wiring box on the front under the bed. No holes to make, you use the one already under the bed that brings the wire out in the back, you add a magnet to the small enclosure you use for the two switches and voil�!
You can have a look at a crude PDF file if you want at this site:
http://www.jeanmichel.org/pub/26020-ModB.pdf
Hope this is of help to you and other turners that have this nice smooth lathe...
Jean.
My Humble site.
Phil Joines Krum, Texas
>Is there something special to this remote? I've worked on 5 or 6 differant VFDs and all any of them needed was 1 single pole switch for ON/Off, 1 single pole double throw for forward/reverse and a linear taper pot, usually 10K or 100K for speed control.
