The red, white, and blue truck came today
Mike Schwing from Maryland
>And it dropped off a box from bestwoodtools.com that contained their modular tool rest system consisting of round stainless bars rather than flat tool rests. Also purchased their 3" precision spindle extension.
I had begun turning a large platter from white ash this morning using the standard tool rest, went to lunch and saw the box at the doorstep. First impression was "wow, big, meaty stuff." Changed out to the new rest and started turning. At first I didn't put two and two together but marveled anyway at how the tool was gliding smoothly along the workpiece, and then realized it was due entirely to the new toolrest.
The ability that the round style rest gives is remarkable! Remarkable! I don't think I'll be going back to the flat one any time soon. The only possible drawback is that with the straight bar the vertical post on the banjo sticks out farther than the rest, so getting the rest immediately next to the work when the rim is in the way - on insides, isn't really possible. However, I bet I can remove 3/16" of material from that banjo's corner and solve that problem. I also received the 4" radius curved modular rest. Very nice!
The spindle extension had no measurable runout using a caliper with a magnetic base stuck to the lathe bed, and it weighed a couple of pounds on its own - big beefy piece of work. I like having a little extra room in between the headstock, but wonder if it'll have a negative effect on the bearings eventually.
Why didnt' you guys tell me how nice round tool rests were?
Re: The red, white, and blue truck came today
-e-
>sorry, i've been trying to keep the 'secret' for years now ...
...and what's so nice is that when you upgrade to a oneway(ok, its my own mean giggle), you only have to buy a new post to keep using their system...
ain't it nice to find something that make it easier to work?
David Galloway
>Mike, I had the same experience that you had and now mostly turn on the round rests. The modular system is truly inspired and with three different post for my three lathes, I can interchange the various set ups. The folks there are superb with customer service. Good call on your part.
David
Mike Rubes
>Hi Mike,
I've got a set of round rests from Best Tool as well and really like them. It took me a while to get used to some of the different feels wrapping my fingers around the round stock, but I really like it now.
I do love the way the tool slides right across them!
Mike
David Hammond, in Powder Springs GA
>A package delivery is always so nice - and a good tool rest is also wonderful. It's the little things like that that make turning so much more enjoyable.
David
Doug Trembath
>Actually, Mike, I think we did!
(chuckle)
Really, just teasing! I've been building them for myself and others for a few years. My buddy bought their system for his 1236, and just loved them. At the same time, I had put riser blocks on my Delta lathe in order to turn bigger pieces, and needed a toolpost that was much longer, so I just got some stainless remnants at my local steel distributor and built my own. I didn't polish them up like Bestwoods does, they don't look as pretty as your new ones, but they sure made a difference in turning, and cost about $3 each. They also don't have interchangeable threaded posts. I really didn't like that idea, I feel a dedicated post welded solidly to the rest is better for someone like me who beats them up pretty badly.
Now I need to replace the cast rest on the Vic, and make the curved adjustable bowl rest. I have all the pieces cut and ready for the time I get the electrical run to my tractor shed so I can finally hook up the welder. Been waiting for the ground to thaw.
I'm one of those guys that appreciates the beauty of a great tool, but am much more focused on functionality versus cost. I like the vibration damping and corrosion resistance of stainless, but cold rolled steel will work real well too, if you keep wax or other protection on them. If you can weld it, stainless is better IMHO.
Is this what you guys keep referring to as a gloat? (:0)
Cheers,
Doug Trembath
Studio in the Woods
Larry Barnes
>Hi Mike glad your enjoying the rests,, what size T-Bars did you buy?
Mike Schwing from Md
>I bought the offset 9" T-bar with 6" and 3" offsets. Also got the 4" radius adjustable length curved rest. I should have bought the 12" bar instead of the 9" one as most of my turnings lately are large and I like to have a bar that goes from rim to center and an inch or two farther to the right. The 9" bar doesn't quite cut it.
Plan to order the tailstock chuck adapter so I'll get the 12" bar at that time. What a marvelous feel the smooth round bar gives to the tool!
Re: stainless steel ????
Bob Elliott
>Mike,
I did not know that these rests were now made of stainless steel.
The only Best Wood Tool rest I have is a 4" round rusty thing.
Bob
Central FL Woodturners
Space Coast Woodturners
