Turning blank storage ?
Harvey Bernstein (Phreezing in Philly)
>I've been cutting rounds into bowl blanks and sealing them w/ anchorseal. I just got a Husqy 350(what a sweet machine!!) and needlesss to say I just want to keep cutting up the rounds.
My question is: Can I store these sealed blanks outside under a tarp like I had the rounds(temps here are varying from freezing to warm each day) or do I need to leave them inside now? I have a lack of room indoors and that's why I'm asking.
Thanks in advance,
Harvey
Re: Turning blank storage ?
TDaniel
>Harvey, nothing is going to be fool-proof. Each kind of wood will be different; some will crack, no matter what you do, some doesn't crack too badly, etc. The best advice I can offer is to turn it as quickly as possible and then give it a coat or two of Anchorseal. Until you can turn it I have the best luck by leaving it in whole log form; others seem to like to cut it into short pieces and Anchorseal them. Just jump in and start trying things, you'll lose some no matter what, but you will be on the road to gaining experience that will guide you the next time.
Loren Brooks, Joliet Il
>I was told alway leave them rectangular if you are not going to turn them right away. This way if they do crack you can still get a nice bowl with out the cracks. I hope that make sense. So if you have a blank that is 6 inches wide and 10 inces long and checking dose happen you still can get the 6 inch bowl. hope that helps.
Loren
Joliet, Il
I do understand and that is how...
Harvey Bernstein ( Philly)
>..strictly by accident, that I have been leaving them. Due to my limited space, I'll try leaving some inside the shop and some outdoors and experiment, like Mr. Daniels suggested.
Thanks for the reply,
Harvey
Thanks, I'll experiment and
>limit the outdoors storage to just a couple of unroughed blanks for the time being and see how it goes.
Thanks,
Harvey
Jim Pugh in Ohio
>Harvey, I find that I can put the round blanks in a plastic garbage bag and they will keep much longer than just leaving them laying on the floor. They may mildew/grow fungus but that is mostly on the surface anyway. It doesn't hurt to dump them out of the bag every 6 weeks or so and let them dry for a day before re-bagging. So, another variation to try.
Thanks for that idea Jim.
