LATHE + WHAT OTHER POWER EQUIPMENT?
Ron Eberle
>I'm thinking about getting into wood turning, but I need to know what other types of power equipment you should have besides a lathe. All I intend to do is wood turning. Any information you can give me will be appreciated.
Re: LATHE + WHAT OTHER POWER EQUIPMENT?
MikeinCape May
>If you want to harvest your own wood and prepare your own stock you'll need a chainsaw and a bandsaw. Some sanding equipment, such as a system for power sanding and also a belt/disc sander is nice but not a necessity.
Bill Howatt
>It depends on how many "branches" of turning you want to get into. If you want to do segmented work a tablesaw is real handy. Doing pens then a drill press is a good tool to have. Want to glue ups some pieces to perhaps make a large platter then a jointer can be useful.
What I've found is that I probably used every one of my major flat-work tools to support the lathe. Don't despair, like everything else if you don't have a certain tool there are ways around it.
Bill
You will really need
Bill Howatt
>a grinder with the appropriate alumunium oxide wheels or a belt-sander arrangement to sharpen your tools. Then you can think about sharpening jigs if you don't want to freehand your sharpening.
Bill
Richard Allen
Richard Allen
>A dust collector and a powered resperator. An air cleaner can help slow the migration of dust to the rest of the house.
Please be aware that there are lots of oportunities to spend money.
Good Luck
Steve Worcester
>Gosh, what about a truck to haul the logs?
Definately a bench grinder, and a saw of some sort to cut logs. Bandsaw and a chainsaw is ideal.
Andy in Raleigh
>As others mentioned, bandsaw and chainsaw stand out as almost "must haves" if you are going to turn bowls and harvest wood yourself. If you are doing spindle work (candle sticks, tops, yo-yos, small boxes, etc) from turning blocks, then your needs are a lot simpler. I would suggest turning a lot of scrap (if you get construction scrap, make sure it isn't treated exterior grade stuff) before getting anything additional.
If you do get a bandsaw, the 14" with a riser is pretty much the minimum (but also seems to be the mainstay) for turners.
Ron Eberle
>I'd like to thank everyone for their responses. You've giving me somethings to consider before I go further. Thanks for your time and help, Ron.
