2035 spindle
>As some of you know I got a new Powermatic 2035A. they've changed several things from the previous models to improve the lathe. One change however was to extend the spindle and add a notch so you could lock the faceplate on with a set screw. Good idea unless you happen to own several chucks of various brands. they screw on and stop as they contact the face of the threads. They don't bottom out against the flange like they should.
I made a metal adaptor ring to fill the void and then contacted powermatic. They sent me 2 of the plastic washers they sell to keep the chuck from locking up on the lathe. They work perfectly.
Now all my faceplates and chucks work. This was a good idea that didn't take into consideration the wide range of tools that some of us own.
Now if they'll just include indexing with the lathe.
