Inherited pen blanks from NZ, not sure how to turn
Caleb in Carnduff
>I've inherited a few hundred pen blanks from NZ (honeysuckle, rimu, pahutekawa etc), from an old family friend that passed away. He used to turn the pens as a hobby, sell them at craft sales and forward the proceeds to charity. I'd like to continue that tradition in his honour.
My problem is I don't know how he made the pens. I've made the standard 7mm twist pens and jumbo pens. The blanks I have from him are all 5/8" by 5/8" by 8" and he would turn a simple design and use a bic or equivalent refill inserted in the nose of the pen. So no metal parts, all one piece. Seems to be a 4mm hole in one end, about 5" deep and then the other end was turned off.
I am guessing that he drilled the 4mm hole in one end, slid it onto a mandrel and then gripped the other end with a live center.
My problem is I don't know where to get a 4mm mandrel! OR could he possibly have mounted it some other way?
Could the blocks be used for anything else? They seem too skinny for a jumbo pen...
Re: Inherited pen blanks from NZ, not sure how to turn
JManuel
>I make pens like these. I hold them in the lathe with a Nova chuck, and run a live center in the hole on the other end. I drill a long 1/8" hole that fits the bic pen filler...and enlarge the very end of the hole to 5/32" which makes a snug press fit for the pen.
Since I don't turn "around" the hole like you would on a mandrel...there are a few blanks that ruin because the hole didn't drill straight and you turn thru it while shaping the pen.
Pascal Oudet
>You lucky guy. pohutukawa and rimu are good woods, which are normally not available outside NZ (commercial export is not allowed for NZ native timbers, except swamp kauri). treat them with care and enjoy !
Re: Inherited pen blanks from NZ, not sure how to *LINK*
Fred Holder
>I did an Project Article for the New Zealand Woodturning Association magazine some time ago on turning this type of pen with a loose square ring on the end. In either the May or June issue of More Woodturning, I will have another one on the subject but holding the wood differently. If you can't find the story in the New Zealand Woodturning magazine, I could perhaps e-mail you the text for the story. Send me an e-mail if interested.
Fred Holders Domain
Caleb in Carnduff
>I won't tell you about the bowl blanks I got then...
