Beading tool
Beading tool
Beading tool
Chuck Ludwigsen
>Craft Supplies USA (good people) has a beading tool listed in there new products section called the Sorby Easy Beader. This basically just looks like a V shaped scraper ground concave on both sides.
I have a couple V shaped scrapers I hardly use. Am I thinking right and does it look like this should be doable?
Chuck in Memphis, TN.
(here is CSUSA's image of the tool)
Re: Beading tool
Re: Beading tool
>chuck
I think it's very do-able. you could reshape your grinding wheel with a diamond hone or just grind very carefully. You could probably grind it close with your grinder and then do the final shaping with a Dremel and abrasive wheels. John
Re: Beading tool
Re: Beading tool
Ron Sardo in PA
>I would just sharpen the top of the tool with a diamond stone and leave the profile alone.
Re: Beading tool
Re: Beading tool
Ron Sardo in PA
>That is once you achieved the profile you want.
Re: Beading tool
Re: Beading tool
Chuck Ludwigsen
>Hmmmm. Sounds like a plan is brewing. Thinking I'll be making another tool.
Okay, so I have a spare coarse wheel that I can use for the main shaping. Switch to a finer grit wheel to clean up the bevel and concave shape. Then clean it up with a round diamond stone. It already has a handle, but since it will be homemade, I will probably knock that off and turn another one.
One beading tool coming up. I'm thinking I need to add a photo album to my website that is nothing but tools and jigs.
I still have to heat-treat the 1-1/2" wide X 1/2" thick heavy scraper I made.
;-) I'm enjoying this waaaaaay too much.... NAAAW.
Re: Beading tool
Re: Beading tool
>Chuck
If it works similar to the other beading tool you approach the work from below center and raise the tool through the cut. It cuts cleaner that simply pushing the tool into the work. I agree with Ron, polish the bevel of the tool and then only sharpen by using a fine stone or diamond hone on the top.
Have fun. If I wasn't demonstrating in Hickory NC this weekend I would make one just to see how it works. I have some planer blades left. I would cut off a chunk and mount it in a cold roll bar. The HSS should hold an edge better.
Re: Beading tool
Re: Beading tool
Russ Fairfield
>These tools and their full-bead counterpart look to be a good way to make a bead. However, there are a few problems with using these and other shaped forming tools.
A different tool is required for each size and radius of bead.
The wood is being cut along the entire length of the formed curve. This tool is a crude scraper amd high cutting forces and tear-out can be a problem. Chatter is always a problem on long spindles.
Most wood is easilly burned from the friction at the tip of the tool. Unless you like the burned accent, you will have to turn the wood very slowly to prevent burning; and the slower speed will usually mean more tear-out on the surface of the bead.
Since you already have a pointed scraper, it can be used as it is to form very acceptable beads; or you can use a parting tool laid on its side to do the same thing. Plunge the tool straight in to make the bottom of the groove. Then back the tool out of the groove while swinging it around to the side to follow the shape of the bead. Then do the same thing on the other side.
There is no restriction on the size of the bead, there will be no burning if you are careful, and the narrower shaving being removed will leave a better finish.
Re: Beading tool
Re: Beading tool
Don Evans
>Russ;
I've got to agree with your approach. The only time I see a special tool like this being worth the cost or effort to make is if your doing those vases with beads from top to bottom. Then consistency in size and the number being made would make this tool very comforting.
Don
Re: Beading tool
YoYoSpin
Re: Beading tool
YoYoSpin
>Chuck,
I bought one of these little V-shaped beading tools the other day, and I like it a lot...it's easy to use and makes a very consistant cut. Note the "beads" cut into these two recently made pen display Lazy Susans. You could probably grind a 1/4" to 1/2" roundnose scraper into a similar V shape, and accomplish the same end.
best regards,
Ed D.
Re: Beading tool
Thanks!! re. Beading tool
Chuck Ludwigsen
>Wow! Thanks everybody. I love these collaborative design discussions and the usage instructions saved me posting a second thread (thanks John & Russ).
Ed, those pens are something. SWMBO tells me I can budget for a pen mandrel in April so I can't wait ;-).
I'll keep y'all updated and post the tool and turning when completed. What got me interested in this was Wally's vase and then seeing this tool at the Craft Supplies USA web site.
Y'all are the greatest.
(updated my website a bit. Take a peak)
Life Takes a Turn
Re: Beading tool
Your Web Site
Clem Wixted Jonesboro, AR
>Just checked out your web site and liked the hollowing tools there.
Did you make them?
I picked up a bunch of tips, like the triangular one shown, at a yard sale.
I now have the beginnings of a hollowing tool. All I need are a few tips, hints and instructions.
Do you know any sources for these tips and instructions?
Clem
Re: Beading tool
Re: Beading tool
Chuck Ludwigsen
>Clem! You are in Jonesboro. I'm in Memphis. Shoot me an email with your phone number and we'll arrange a day for you to come over and I'll SHOW you how I made them. Pick up a 5/8" or 3/4" steel rod and an Ash turning square from "That Wood Joint" and you just may leave with a tool.
Seriously, it was fun. Ryan and I are cutting up a bunch of Boxelder tomorrow night, but we can possibly do something Saturday or next week.
Talk to you soon.
Chuck
Re: Beading tool
Mini tool
Phil Joines Krum, Texas
>Here's one made from a 1/4" square x 2 1/2" long cutter bit. The bit was shaped using the edge of an 8" wheel. It's 6 1/4" long. The ferrell is a brass pipe cap that had the flats cut back with a scraper.
It does a good job on pens and small goblets.
Re: Beading tool
Re: Your Web Site
Don O.
>Check the posts from a few days ago on the basics of hollowing. Some great advice there. Scroll down or use the search function for "hollowing"
Amazing amount of info here isn't there?
Happy and Safe Turning, Don
