Green apple goblet
Dave Smith
>I took this picture before the goblet self-destructed. I was pruning the two apple trees in our back yard that my wife wants me to cut down. I decided to cut off a limb and do a goblet. Any excuse to turn. The motivation for doing this was an article I had read that morning about turning goblets on Larry Hancock�s web site.
The goblet is 6" tall. Stem is about 1/8". Cup is 1/16" thick on top and 1/8" on the bottom sides. The cup rim is about 2 1/16" in diameter and the base is about 1 15/16". The pith is not centered. I sanded to 320 as I went along but didn�t apply finish. When parting off I didn�t want to catch the goblet but I was holding it before I knew what happened. Later in the evening I noticed that the transition area was starting to crack and I applied some gel poly to the goblet. I figured it couldn�t hurt. The goblet was still standing this morning. I left too much material in the transition area between cup and stem. Had I made the cup more uniform in thickness the transition area would have been thinner and less prone to cracking.
For turning the stem I had the best results using a Sorby �" spindle master.
Dave Smith
Pruning trees in Longview, WA.
