Some new work - and new camera
Mike Schwing from Maryland
>Finally got a replacement camera.
First, the two tall forms are totally new for me. They're end grain, were turned wet and dried in paper bags. They're mostly dry now, and it doesn't seem that they moved much, nor cracked, while hidden away inside of two paper bags and taped shut. They were both done as pith in the middle, end grain turnings, from whole logs. These are both quite substantial pieces for me. Sure take a lot more time than small bowls.
I used the Ellsworth grind exclusively on both of these, but I ran out of tool handle on the taller one (14") and got a catch at the bottom that I couldn't remove entirely. Hard to see that far inside anyway.
I had no trouble removing all of that end grain with the Ellsworth grind, and used a LOT of cuts number 3 and 4 as pictured earlier on this forum. I'd hollow out an inch or two using normal tool presentation and then remove the rest of the sides' material using cuts 3 and 4. NO catches and a remarkable finish.
They're both sanded to 500 and mostly drenched in walnut oil before putting them away in bags. I checked inside the bags every now and then to see for cracks.
The third one was fun, quite a challenge, but I don't really like it much. A cherry burl I tried to do something different with.
Cherry - unfinished, might stay that way. 14" tall x 8" wide at top"
Apple - 9" tall x 5" wide at top. Walnut oil.
Cherry burl bowl. Dry. Varnished.
