Home made Bowl Lathe
Phil Joines Krum, Texas
>Almost complete bowl lathe. The tool rest support post has too much play. I think I'll replace the 2" pipe that ties the stand to the lathe with a rectangular piece. There's also a free standing rest in the works.
The frame is mostly 2" square 3/16" thick tubing with a 2 1/2" angle iron base.
The headstock is a cast iron 4 cylinder engine block. The spindle is 2 1/2" dia and rides in pillow blocks at each end. It's 43" above the floor. The nose is threaded for 1 1/4" x 8 to match my Nova 300. Power comes from a Leeson 3 HP VFD. The pulley on the motor is the smallest I could find. The spindle pulley is a 5 step with the largest 5 1/2" dia. Since the lathe will be used primarily for large pieces I'm thinking to replace the spindle pulley wit one in the 7" to 8" size.
Once a place for the lathe is figured out in our some what crowded shop the bottom will have a piece of 3/4 ply installed and the space filled with sand bags. It's already heave enough that I have a hard time moving it at all.
