Time to take the plunge
JHD in NC
>It's time to show some work. Not the best pic's but you can see the work. Two bowls are cherry burl. big one 7.5" by 4". Small one is the center of the big one cut out with parting tool 'hated to see it all on the floor.' It is 5.5" by 2.5". I have ben to lazy to cut off the foot. The osage orange poppuri was fun to turn. This is some of my frist turnings. I am off from work today ( snow) so I thought I would take the plung and post some work. the better work is in the store hoping for a new home ;-} I am going to try to add the pics in the post hope it works. Thanks for looking and for good and bad reviews. John
Re: Time to take the plunge
Chuck Ludwigsen
>I haven't tried using a parting tool to core out a solid piece. How well did it work and would you try it again? Seams like you would have to go REAL slow and overhang the tool rest un-supported quite a bit.
Chuck in Memphis, TN.
JHD in NC
>I saw how to do this with waiting for an order to be filled at Packard wood works. I live in the same town so no need to order online, and they are great to deal with and let me look at the books. I did it while between centers and from head side. Had to make several passes to make room for the tool or it could have been bigger. When it felt un-safe I removed the piece and used wedges to break it loose from the large one. I got it down to about 1.25� before removal. It really wasn�t that hard and I got to save that great piece of burl hate a floor full of chips that could have been a bowl. One day I will be and to get a coring system. But need to finish house and shop first. I have done this on others large blanks without any problems just keep it sharp. Thanks for looking John
Ron Sardo in PA
>I parted a core with a diamond parting tool. The maple blank was 6x6 leaving about 1-1/2" walls and the usable core finished up about 2-1/2x4. The parting tool is 3/16th wide and the cut I was making was about 3/8" wide, maybe more.
I don't know if I'd do it this way again unless it was a REALLY special piece of wood.
Would a coring system fit on a Jet 1236?
You Plunged Good
Glenn Hodges
>Hey John, nice looking. What kind of finish did you use to get them that shiny?
Nashville, Georgia
Re: You Plunged Good
JHD in NC
>It is not the final finish. I sprayed on some bulls eye to seal and it also act's a binder on the cherry burls. Spray heavy soaks in and hold together what would normaly dry srink and fall out of the burl. Learnd this from and 92 y/o wood worker. To finish I will sand off and wax, oil turns the cherry to dark. John
