bandsaw blade
bandsaw blade
bandsaw blade
Dennis Taylor (Akron, Ohio)
>I have a 14in Grizzly bandsaw comming to my door on Monday, and a gift cert & 10 percent off coupon in hand for woodcraft, what is a good timberwolf blade to get?...want to cut up stock and maybe resaw small boards/...Dennis
Re: bandsaw blade
Re: bandsaw blade
Sean Troy
>Timberwolf 1/2" 3tpi hook .032 This blade will work great for blanks, wet or dry. good luck, Sean
Re: bandsaw blade
Re: bandsaw blade *LINK*
John Trant (aka Boxes-n-Bowls)
>Buy your baldes directly from Suffolk Machinery (makers of Timberwolf); it is a lot cheaper, even with Woodcraft's 10% discount.
John
Suffolk Machinery
Re: bandsaw blade
Re: bandsaw blade
Larry
>Unless you are doing precision sawing (making blanks and rough resawing is not) or doing production work, you are wasting your money on Timberwoolf blades @ $40 a pop. The generic woodcraft blades work fine, last a long time and @$11 don't make you cry if you run into a nail or other hard object when sawing up harvested wood.
Re: bandsaw blade
Re: bandsaw blade
Terry Quiram
>Dennis
Good advice from John. Call Suffolk and tell them what you want to do. They will recommend a blade that will fit your requirements. My resawing Timberwolf blades are 124 lg, 1/2" 3 tpi and cost $24. I use an LT16
Terry
Re: bandsaw blade
Re: bandsaw blade
Jerry Whitaker
>I would go for the Timberwolf blade directly from Suffolk Machinery. They are half the price of Timberwold from Woodcraft and are much better than the Woodcraft brand too. They have quick service and are very helpful over the phone. I use 133 in. blades on my 18in. Jet and use the 3/4 in for re-sawing with excellent results.
