A55 Smoothing Plane
Using Turquoise....
Using Turquoise....
Using Turquoise....
Wally Dickerman at Green Valley, Az.
>There have been a couple of recent threads on using turquoise or inlace to fill voids in turnings. I sometimes use crushed turquoise, mixed with epoxy just to enhance a piece. This one is Myrtlewood and it's 10 inches in diameter. Already been sold.
Wally
Re: Using Turquoise....
Ron Sardo in PA
>I've said it before and I'll say again... I love your work Wally!
Beautiful!!!
Tony Augruso
Wow!!!
Chuck Ludwigsen
jim reasoner
>That is beautiful work. From your other message below on filling voids I assume you apply some oil to the wood around the circle grooves then fill with the epoxy-turquoise. Where in the world do you find ground turquoise? Do you mix the turquoise into the epoxy then apply it or do you put the epoxy in first and then mix the turquoise into the grooves? I suspect it is all mixed first.
>Jim, I live in Arizona where much of the turquoise comes from. I cut shallow grooves with a small parting tool. I mix the turquoise with epoxy, making sort of a paste, and apply it to the grooves with a small spatula. Ask your dentist for used dental tools to poke the stuff in well. I got 6 of them, some bent. I'm glad he didn't bend them on me! I use a right angle drill and 80 to 240 sanding discs to bring the turquoise down to the level of the wood. I add a little gold dust to give it some sparkle.
Wally
Mike Rubes
>Hi Wally,
That's really great! The wood is spectacular and the inlay just makes it even better. I like having the inlay set in that slightly raised area, it sets it apart even more.
Very nice photography on that piece as well. Good use of lighting and the black background.
I hope all is well in Arizona, we are just starting to warm up here in NC.
Mike
Brian Roberts
>Hi Wally - VERY nice! The bands seem to be "in harmony" with the shape - not too much - just enough to accent well.
Brian
