Homemade "inlace"
Mike Schwing from Md.
>Ron's topic was particularly timely for me. I have a cherry bowl that just would not stay together, but a smaller one from the same block did just fine, turned the same day, same way. Anyhow...
I went over to our local crafts store, "Michael's". They have a BEWILDERING array of glitters and embossing powders, all pretty inexpensive as far as I'm concerned. Many different "grits" of glitter, tons of colors, ground stone, .5 mm sized "marbles", etc...UNBELIEVABLE amounts of stuff. I chose a few to experiment with. The pic below is a 10 minute repair job/test with glitter that I now think was too fine a grit. I used thick and thin CAs. Taped one side of the gap, tapped in some glitter, added a layer of thick CA then some accelerator. Did same until crack was nearly filled, then dusted on some more and sealed it up with thin CA. Sanded down fine. A 1 oz container of this fine grit glitter was maybe $1.99, their other, not so fine grits were half that price. I'll try another later this weekend, my hunch is that the less fine grit will look a little nicer. Either way, the experiment definitely was worth it, I'll be using this method again!
BTW, they have enough colored "embossing powder" that you could probably make a nearly invisible patch job on just about any wood.
