Dust filters and furnace blowers
Arch
>I plan to cobble up two supplenentary dust filters from air condx filters and furnace blowers. I have heard that used this way, air flow has to be restricted to prevent overheating the blower motor. If true, do I narrow the inlet or outlet? What is the best kind and how many air condx filters stacked in line for best air flow and filtering? Any discussion re these units and advice or referral to relevant sites appreciated. Arch
Re: Dust filters and furnace blowers
Stuart Johnson
>Arch,
Can you receive or view word documents with WEBTV? If so I have have a copy of the air filter Herm from WOW built. I can send it to you or stick a copy on my web page.
RPE
>Arch,
It dosen't matter whether you restrict the inflow or the out flow.
The best way to find out what your particular motor will withstand is to put a clamp on amp meter on one of the blower leads. Start putting filters or in some way start restricting the airflow. You will see the amps fall off. Try to get the amp rating of the motor off the placard if it is still there.
Just get the amps at or below the rating.
It is usually around 7 amps for blower motors.
RP
Arch
>RP, thanks for your good help. BTW, I see that HF has a dgital clamp-on meter for sale for $10. I don't know if it has the proper amp ranges and accuracy for testing the blower motor?
Stuart, thanks. I can receive the info on webtv. It's not great as a computer, but it will put the cat out and dry the dishes! Alternately,I wonder if there would be enough interest for your posting his plans here? I'm quite sure Herm would approve. Arch
Gary Bills in NC
>Here is a shot of my hood made from a 5 gal. pail. I just roll the whole unit up to my lathe and start sanding.
Gary Bills in NC
>Here is the dust filter I made. I bought the filters from Grizzly. The bag filter goes down to 3 micron. If you filter this small, I don't think you'll have to worry about restricting the flow, since the filter does that. I push the air through the filters but pulling would work just as good.
Peter Teubel
>What's the stock number for that $10 clamp on ammeter from HF? I can't seem to locate it on their site.
Arch
>Thanks Gary, Good ideas.
Peter, I noticed the meter in a HF sale flyer.
Lot no. 42396 $9.97 Regular price $ 17.99
Sorry, I Don't know the specs or quality. Arch
Peter Teubel
>Thanks Arch. Its now $14.99, but that's still quite cheap.
