Bent Bowl Gouges
George Troy
>Has anybody ever tried bent bowl gouges and if so where can I find them? Many of my segmented bowls are southwest style. Dried hardwoods at times can be difficult scraping after gouge work. Curves can also be troublesome. If you want to turn thin you have to step it down and I do. Working on some super thin segmented bowls now, less than 1/8". Sometimes I need to tickle up of down to take some dips or high spots out. If I have room a freshly sharpened gouge does the trick. When I have to swing around and the gouge hits the side, them I'm out of luck. I would like to try a gouge with a bend to cut where I normally scrape. If I can't find one, then I will heat and bend. Somewhere someplace I remember seeing a bent bowl gouge, now I can't find it. I was thinking England or Dennis Steward. I have most every scraper tool out there. So this time I wanted to try a gouge.
