Long thin turning
Paul Vander Woude
>Hi folks. This is my first question on the turning list, tho I've been around WoodCentral since its inception. My wife asked if I could turn her some knitting needles out of Ebony and Rosewood. Most everything I make is flat or square, though I do own two lathes- a Sherline, which I have used for small turning (pens, etc.) and an Atlas 10 x 52 metal working Lathe, on which I've done mostly metal work, tho I've turned some banjo rims on it with a riser block. Now for the question: How would I go about turning something long and thin like a knitting needle (say 12 to 14" long, and 1/4" + or - diameter.) I'd be starting with flat stock. I don't have a 4-jaw check for either lathe- just 3-jaw chucks and face plates. If I had a 4 jaw chuck, I could see starting with a square cross section and turning a few inches at a time, and advancing it in the chuck, using the cross slide to turn each segment to the same diameter. I'm concerned about vibration, and flexing of the piece when it gets thin. Any thoughts or suggestions?
