turning with inlays
turning with inlays
turning with inlays
John Piwaron
>What can anyone tell me about turning a bowl or vessel that's had a
crack filled with an epoxy/turquoise mixture. I've seen some work
like that, and just wonder how that's done considering that turquoise
is a stone. I'm thinking the tool being used mustn't like that too
much.
Re: turning with inlays
Wally Dickerman at Green Valley, Az.
>John, you're right, turquoise is a stone and turning tools won't work well. I often use crushed turquoise mixed with epoxy to fill voids in wood. I use my right angle drill with 80 grit sp to bring the turquoise down to the level of the wood.
Wally
Scott Greaves in Blackfoot ID
>Hi John,
I think Wally's way might be the best. But I have also turned the stone down using a carbide skew I have. I think a carbide scraper might actually be a better way to go. Just buy a carbide insert off of Ebay, a couple of bucks, and super glue it to a steel rod with a flat ground on one end.
Good Luck!
Scott.
YoYoSpin
Here's a look-alike alternative
YoYoSpin
>This Birch Burl box's body is filled with fine blue glitter and thin CA...cheap and easy work with.
best regards,
Ed D.
Re: Here's a look-alike alternative
Glenn Hodges
>That looks great, thanks for the suggestion, I believe I will give it a try.
Nashville, Georgia
Bill Hale / The Wood Spinner
>It seems we all work almost alike. When I set the stones I keep them a little deep and fill over with CA. Cutdown the CA with your tool of choice and sand down the CA and not the stone.
Fast and easy. At 600 grit the CA is shiny clear.
Good turning and be safe
Bill
John Piwaron
>True awesome work and great suggestions. Thanks.
very nice piece of work Wally!
Mike Schwing from Md
>I REALLY like that bowl! Great shape, superb retention of the natural edge. Something to aim for. Maple burl?
