200+ woodworking book reviews
Pencils and Pens
Pencils and Pens
Pencils and Pens
Phil Smith
>I have recently started to turn some pencils and pens. They are going to be presents for some of the out of town guest at my daughters wedding at the end of the month. The pencils are based on the style that Nick Cook teaches and the pens are one piece barrel design. I've made about 18 pencils so far. Have about 4 more to make. Have made 3 pens so far and have 3 or 4 more to make.
Hope the picture work, this is my firt time for posting pictures.
The first pencil is cocobolo with pentel mechanism.
The second pencil is cherry.
The pen is out of cocobolo
Re: Pencils and Pens
Peter Teubel
>Excellent pen/pencils. What is your photography setup? The pics are excellent too!
Ted Calver
Ted Calver
>Phil,
I've been wanting to try the pentel pencils for some time but haven't figured out exactly how to do it. Can you point me to some instructions? Thanks
Ted
Phil Smith
>I took a spindle turning class last summer from Nick Cook in Atlanta. One of the things that Nick showed us was how to turn pencils using the pentel mechanism. You will need a step drill to drill the blanks. The drill is available from Craft Supplies USA. Nick has a good description of the process on his web site. Look at the Pencil Pusher article in the link below.
http://www.nickcookwoodturner.com/articles.htm
I turn the pencils entirely with a skew. Use 1 1/4" to turn the blanks into cylinders and then finish with either the large skew or switch to a smaller 1/2" skew.
The turning tools used to make the pencils were all home made. The skews are out of CPM 3V particle steel, Parting tool is out of an 1/8" M2 tool bit for metal working and the Bedan was made out of a peice of 3/8" square piece of tool steel.
Phil Smith
>A friend took the pictures for me. He used one of the new Cannon digital SLR cameras with a indirect flash. I think that it is a 6 mega pixel camera.
Rick Prevett
>Hey Phil,
Like Ted, I'd like to try to turn some of these Pentel pencils. I took a look at Nicks page and like his tutorial. There's a couple things I missed though. Do you purchase the mechanisms separately from somewhere or do you dis-assemble a store bought pentel? And how do assemble the pencil once you have the mechanisms?
Thanks for any input on this subject. I really like the single piece pencil look you have achieved.
rick
Phil Smith
>I buy Pentel pencils from and office supply place such as office depot. I screw the tip off and pull the mechanism out of the plastic barrel and insert into the new wooden barrel and screw the tip on. I throw the orginal plastic barrel away.
I you want to use the clip I file a very small flat on the side of the wooden barrel after sanding to 400 grit with a small triangle file. Then sand with 600 grit on the lathe to smooth out the shoulders on the flats. I slip the clip on after the pencil is finished.
Ted Calver
Ted Calver
>Phil,
Thanks for all the help!! My heavy hand seems to snap normal 5 and 7mm leads every other word and Pentel is one of the few makers out there who still make a decent (and cheap) 9mm drafting pencil. Gonna make up a few...but they probably won't be as nice as yours!!
