THE WOODRAT IS BACK!
Dust Collection Question
Bob Moffett
Bob Moffett
>I am in the process of installing a DC system in my basement workshop. I am a hobby woodworker. I have a Radial Arm Saw, Table Saw, 16" Lathe, Router table & 6" belt sander I would be hooking up. Naturally, I use the Lathe the most and it would be about 10' from the cyclone. I am more interested in capturing sawdust than shavings. The shop is 20' X 16' with the longest run being 20' or so to either the router table of 6" sander. I have made the Wood Magazine Cyclone and am wondering which would be best to hook up to it, a Delta AP-400 or Jet DC-650CK. Or would I be better off selling the cyclone and using a Delta 1100 cfm bag DC or Jet 1100 cfm with the filter.
Thanks in advance for your help.
Bob M.
Re: Dust Collection Question
Re: Dust Collection *LINK*
Dennis J. Gooding
>Bob, I also built one of the Wood Mag cyclones and have been happy with it. However, my experience is that it is futile to attempt to collect chips from the lathe with a DC. Its main value is in collecting sanding dust when sanding and diverting irritating dust away from the face when turning noxious woods. I don't see that it matters what lathe you use with it. The important thing is to get end of the collector hose close to where the dust is being generated. My solution is to attach a band clamp about ten inches from the end of the 4-inch collector hose. (More or less depending on the swing of your lathe.) I epoxied a rare-earth magnet to the band clamp. A half-inch magnet more than strong enough for this purpose. This allows me to position the end of the hose just about anywhere I like in the work area of the lathe. There are no hoods to adjust or get in the way. Good luck. Dennis
To respond remove the 2 from the address.
http://www.roundthewoods.com/hooktool.shtm
JamieDonaldson
>Here is an easy to make and very effective dust collector hood-made from heating/AC duct return. As you can see, it connects to the lathe 4" collector with a high tech adaptor, a Maxwell House can! I can switch it around to several other shop tools very easily.
Bob Moffett
Re: Dust Collection
Bob Moffett
>Dennis,
Thanks for the information. What size dust collector are you using with your Wood Mag. Cyclone?
Thanks,
Bob M.
Bob Moffett
Bob Moffett
>Jamie,
Thanks for the idea on the hood.
Bob M.
Joel Hunnicutt
>Hey Bob, just get Charlie to clean up after you :). I have a 1 1/2 hp penn state 2 bagger and it does a good job with the bandsaw and the planer, but it is a 20 ft run to the lathe and it doesn't pick up muck sanding dust. The best dust control I've found for the lathe is a 20 inch box fan set up to draw air with a furnace filter on it.
Re: Dust Collection Question (link)
Jake (MN)
>Check out this link, very informative for cyclone
http://cnets.net/~eclectic/woodworking/cyclone/Equipment.cfm#Introduction
remove the 2 for email
