Shop Built texturing tool?
Dominic Greco in Wet! Richboro PA
>Hey folks,
I stopped by Woodworker's Haven today with the intent of purchasing a Sorby Spiraling / Texturing Tool. I've been meaning to get one for some time now and decided today was the day I picked it up. Of course when I got there, they were out of stock.
Who knows, maybe this was a sign that I should ask this question before I go and plop down approximately $155.00 for this tool.
I seem to remember reading about a woodturner who made his own version of this. I'd like to see if this is worth pursuing, or if I'm better off just buying the Sorby. Anybody else remember this?
I mean, it can't be all that hard to make. It's a handle, a metal rod, and a toothed wheel which is attached via a bearing. It's just that I have no idea where to get the wheels, or the bearings that work with them. :>)
See ya around,
Dominic
Re: Shop Built texturing tool?
Re: Shop Built texturing tool? *LINK*
Fred L. - North Carolina
>Knurling wheels. They usually come in pairs to produce a cross-hatched set of lines. You can get a pair of wheels in a holder for $7. at Micro-Mark. For use with a wood lathe you add your own handle.
These wheels don't cut, they produce indentations, so the piece needs support. If texturing bowls it might be easier to texture before hollowing.
Knurling Tool
Local farm supply/lawnmower repair shop
Bob Hackett
>I`d look at these type of places for small sprockets with ball bearings,they`re most often used as idlers or to tension long lengths of drive chain.With alittle handwork(aided by a grinder or Dremel)you can reconfigure the teeth to do pretty much what you want.Most sprockets are hard steel so grinding is the ticket,followed by a diamond hone for sharpening the face(side)is you`re reconfigured it for a cutting tool such as a spiraling tool.
You could also do a Google search to see what type of sprockets are available before going down to the local shop and pawing thru thier inventory.Might help to narrow the search if you had an idea before you stand on that long line at the parts counter,DAMHIKT.;^)
Mainely,Bob
Thanks,....but....
>Where on your site do you document how you made the texturing tool? I looked through the entire site. While I did see some neat stuff on hollow forms and 3 point tools, I didn't see anything on the texturing tool.
Thanks,
Dominic
Bob Moffett
Bob Moffett
>Dom,
I made one using a 1/2" bar with two tabs welded on the end of it. That sort of made a "U" shape on the end of the bar. I then drilled a hole through the tabs and put a bolt through it with a locking nut on one end. I bought the texturing wheel through Klingspore's Woodworking Shop. The stock number for the Sorby Texturing Cutter is SZ00027 and the cost is $26.95. This wheel already has the bearings in it and is ready to go. I would order the wheel before I welded the tabs to the bar, just to make sure you get a good fit. It is better to call them at 1-800-228-000 to talk to someone to order. Their website is www.woodworkingshop.com. I have been very pleased with my texturing tool. I have no affiliation with Klingspore, other than being a customer.
P.S. They also have great prices on bulk sandpaper.
Hope this helps.
Bob M.
Darrell Feltmate
>Dominic
Go to the "make a tool" page and lood at the second one down. Or just go here:
http://www.roundthewoods.com/detail.shtml
Thanks Darrell
Dominic Greco in Richboro PA
>Darrell,
As soon as I saw that page, I realized that you were the turner who I was speaking of! Thanks for giving me the directions to your "How To" page. It contains a lot more info than just on the texturing tool. I liked the 3 Point gouge, and round skew you made as well.
See ya around,
Dominic
Thanks Bob!
>Bob,
I saw those wheels when I was out shopping. But not at that price! That is really a good deal. I saw one at the store for close to $70.00! It's a piece of cake for me to make a tool handle that will hold those. Thanks for posting this information.
See ya round,
Dominic
