mixing various epoxies
Andy in Raleigh
>My initial tests with this seem to indicate it's fine, but I wanted to run it by others in case there was something I wasn't considering...
I have a *lot* of slow cure epoxy left from boatbuilding projects. It's so slow that it's a pain to use in general ww'ing (but slow cure works much better when doing fiberglass work). I came up with an idea to speed it up. I mix a small batch of it and then squeeze in some 90 second epoxy out of a double syringe (the standard bliser pack stuff) and mix it up good. A little bit goes a long way. Mixing about 4:1, I am getting roughly 15 minutes.
-Andy
