Stretch Wrap source and more
Chuck Ludwigsen
>I found the stretch cling wrap I was looking for to use for bowl bottom turning. While there I noted something else that might be of interest.
I got it at the nearby U-Haul rental center. They have quite an assortment of items that can be of help to turners. Here are 2.
- Product name: "Home Stretch"
Description: 2" wide roll with dispensing handle. Film is greenish in color. Package says "Film clings to nothing but itself."
Size: 2" x 500' (yes, feet).
Price: $3.99 (yes, that is right).
Notes: This is WITH the dispenser handle.
- Product name: did not catch brand name...
Description: Packing and protective foam sheets. Used between plates for packing and such.
Size: 3/32" thick foam sheets 12" x 40' (yes, feet).
Price: $4.60.
Hope this helps someone.
Chuck in Memphis, TN.
Re: Stretch Wrap source and more
Fred L. - North Carolina
>Chuck:
Thanks! that should make it easier to get it. Uhauls are all over the US.
FredL
RonZ
>Thanks! Now we all have to hope some woodturning supply company doesn't buy out all the stock and then triple the price and call it 'wood gaurd' or 'check check'. =o)
Chuck Ludwigsen
>Or "chuck wrap".
Teknatool would make a slightly wider variant called "Super chuck wrap".
Oneway would double the price and say that theirs holds more firmly and accurately.
Axminster would repackage the 2" roll as 50mm.
Just kidding, they are all good companies.
Fortunately, more people MOVE than do woodturning, so I think our supply is safe.
Ron Sardo in PA
>I hate to tell you guys but UHaul already kicked up the price. I buy the stuff for my business from a local supplier. I'm not bragging, but I buy a case of 36 rolls for $32.00 (3" x 500'). There are other sizes available up to 18" x 2000'
Two months ago as an experiment, I wrapped a roughed out a maple hollow form with this wrap, filled it lightly with wood shavings. So far the form has not warped or cracked while sitting on a shelf. I'll let you know how it turns out.
Re: Pallet Wrap
Ed Thomas, Toronto ON
>We use it in our print shop too. When running tight register, multiple pass work, the lifts are wrapped shortly after they come off the press. This keeps the moisture content, and therefore the size of the paper, stable. We've been doing it this way for 20 yrs. I see no reason why it wouldn't work for bowls.
Re: Pallet Wrap
Ron Sardo in PA
>We run 4 color process in two passes. This would make life a whole lot easier. Thanks for the tip
same price here in ohio
Bernie
>Thanks picked some up
Re: Pallet Wrap
>We've run 8/8 (YMCK-2PMS-matte-gloss), for a French canal boat brochure, where the quads fit to the gloss ... on a single 25". I wouldn't attempt that without plastic wrap. To get back to wood, I was talking to my ink chemist and press varnish's main ingredient is tung oil which they get for (I think he said) $7/kg or about $2.40US/lb. Wonder if that would work on wood.
LOL!
RonZ
