Did I buy the wrong wheel?
RPE
>I just ordered a Silicon Carbide wheel for my 8" two speed grinder. I didn't even look at what it was made of until today. I just saw it cost more and was green!! I figured that was two of the man ingredients!! Not grey, and cost more!
I ordered a 100 grit wheel. Will it be okay for my HSS tools and my Glaser?
Thanks,
RP
Re: Did I buy the wrong wheel?
Jim Putnam
>I've been using a 7" green wheel with a low speed grinder and Sorby jig. My Sorby HSS tools seem to do just fine with it. The green wheel seems to cut slower and leaves a smoother ground surface. I'm not an expert in this area though and look forward to seeing the remarks of the more experienced folks in this area.
TDaniel
>Green is for carbide but should work fine for HSS, I haven't used it for HSS but I think it should work.
>Terry is right. The green is for Carbide. I will cut slower but I think it would work also. I have one I can try sharpening a HSS tool tonight. Ideally you needed white, pink or blue.
It works fine but
Bill Howatt
>it wears very quickly. You'll probably find you are dressing the stone much more frequently because of the grooves.
I got one in a package deal with my 1700rpm grinder. As soon as it is consumed a white one will take its place.
Bill
