Design Critique Please
George Van
>All three bowls ended in some type of disaster before they were finished. I will have to get a bigger barrel for my destruction bin.
The one on the left was too rotted at the base and kept pulling apart within the tenon. I tried to glue it twice. The middle one was nearing completion when I had a catch followed by another trying to fix a slight bulge in the outside after finishing the inside. Guess I should have sanded the thin wall considering the bottom photo. The on the right blew into three pieces with a catch and I glued it together to see if I could and sanded. Guess my user name should be �Firewood To Firewood�
All catches were with the 3/8� spindle gouge with a fingernail grin as from Sorby. That is why I have the previous post.
Ignoring the photo quality and the finish, am I on the right track for shape and form? With your critiques and Raffan�s design book I hope to improve.
Thanks, George
Re: Design Critique Please
adrien
>1. For starters, don't try to make the bowls so thin. That will give you a little slack if the thickness varies.
2. Sanding can go through a bowl just a readily as a gouge, DAMHIKT
3.Shapes of your bowls are pretty good.
Keith Tompkins
Keith Tompkins
>you are definitely on the right track, George! work at consistant wall thickness....then you are in business!
David Chung
>I personally like a natural edge piece to have a rounded bottom and no foot per se. Just my preference, but you should try it on a piece and see what you think...
Peter Teubel
>Just an opinion:
The bowl pictured has the beginnings of a good shape. However, there are 4 separate transitions as noted in the picture (see RED lines). All these need to flow (see YELLOW line)...not change abruptly.
You're on the right track, though!
Peter, Great Critique
Stuart Johnson
>A good way of explaining and then showing your critique.
George Van
>Thanks to all! You help me learn.
Adrian, I will make things easier on myself and go thicker for starters. I imagine it could be painful to sand through a bowl, maybe better that I did it with the gouge.
Keith, I am adding a double end caliper to my gouge order today.
David, I am going to try a dovetail mount to get away from the tenon and foot tonight. I think I will like that appearance on a round, enclosed bowl also.
Peter, I really like your illustration using the draw tool. What an excellent visual effect. I will use your idea when I have specific design problems in the future. I may even use the tool to play with shapes before destroying the blank.
George
Yes, great explaination Peter
David Eaves
Re: Peter, Great Critique
Peter Teubel
>Thanks, but I must emphasize that I do NOT offer "critiques". I feel I am not qualified in any way to do that. I can only offer my opinion on what *I* think (which may or may not have any value). It just so happens that natural edge bowls like this are my speciality. I've turned many 100's of them and I now have a pretty good "feel" for what makes a pleasing shape.
George, one more thing I'd like to pass along. I used to try to turn these type of bowls super thin. But I found out that the bark texture is lost when thin (you're only left with a "profile" of the bark, so to speak). While it may work for Bert Marsh (whose shapes so thin that they appear to be made of porcelain), side by side, my "thicker" bowls sell better (i.e. 1/4" or more).
Bill Grumbine, Kutztown PA
>Hi George
I think you are off to a good start with your bowls. I would like to add a few suggestions, some of which have already bee voiced. I like simple forms that show off the the wood as well as the form of the piece. In your first picture, if you had continued the curve of the first and the third pieces without a foot or detail at the bottom, you would have a cleaner looking piece. The concave form of the first and the convex form of the third would then flow right up from the surface of the table. I think the foot on the middle piece looks pretty good.
Regarding the middle piece, Peter does a good job of describing what I call "hard spots" with my students. Most of that can be cured, giving you a smooth flowing curve, by learning to use your entire body in the execution of the cut, rather than just your arms. Anyone who has ever been to my shop for lessons will testify that I am a real tyrant when it comes to using one's entire body to make a cut, no matter how large or how small. The difference in results are amazing.
At any rate, keep up the good work, and we will look forward to seeimg your next efforts.
Bill
George Van
>Thanks Bill,
I will make an extra effort to keep my elbows in and use my body until the movement is more natural. I do have a difficult time deciding when to use a foot and when not.
George
Chuck Ludwigsen
>Bill,
Good comments. I want so much to save up for a long weekend in PA in one of your weekend classes. Maybe in 2005. I wonder what the airfare, hotel, and care rental charges would be. Maybe I can start budgeting for that and have my wife give it to me as a 40th birthday next year ;-)
Ya gotta have a goal!!!
Take care.
Chuck in Memphis, TN.
>Hi Chuck
We (the family and I) would love to have you up. I can email you some of the rates, but skip the car rental. We can chauffeur you around from the airport to the hotel (one mile from the house) and so on.
Bill
