REAL MILK PAINT
Making Lemonade out of Lemons
Steven Antonucci
steve antonucci
>So the other day, I was hollowing out a piece of Mesquite with a 1/4" Gouge, when a catch caused to gouge to snap about 3" of the flute off. After a few choice words, I thought to myself...
"What can I do with this?"
After resharpening the remaining flute, I began thinking about taking the remaining 3" and making "hollow bar" bits. I assumed that I could easily cut to length with a Dremel and a cutoff wheel. As it turns out, I knocked the former lead edge of the gouge off in about 30 seconds.
I then went to my homemade hollow bar, which accepts 1/4" bits. Karma. No additional steps required. I placed the bit in the ~45 degree hole, and went to try it out.
This thing cuts so fast and effortlessly, that it has probably knocked my hollowing time in half. I hollowed a 12" Cherry crotch yesterday (1/4") with it in about 1 hour. It's like having a bowl gouge inside the hollowform.
Sorry for the picture quality, but if you look closely, you'll get the idea. A set screw hold it in place.
So if you have a "used up gouge" laying around, or have some broken tips, here's something you can do with them.
Steve
P.S. Yes, my garage windows are that dirty...
Re: Making Lemonade out of Lemons
better get a patent on that quick!
Mike Schwing from Maryland
>that is exactly how new and better tools are created. Congratulations, a few years from now this might be known as your tool all around the world. Unless someone has beaten you to it, of course...
Two already have
Bob Hackett
>Lyle Jamison and Jacques Vesery are two who use gouge tips to hollow.Sorry to burst the bubble.
Great aplication of available resources though!As Mike said,it`s this type of approach that brings on the innovations in any craft.
Mainely,Bob
Steven Antonucci
Didn't think I was the inventor...
Steve Antonucci
>Just a guy who hates to throw anything away :-)
I guess I did a commercial for both of them, 'cause it sure works.
Steve
Sean Troy
>Mesquite? Couldn't be. lol Glad to see something good came out of a jacked situation. Sean
Kirt
>Great idea!!! Any chance that you could post a better picture?? Do you present it in the same way you normally would with the regular 45 degree hollowing tool?? I also have a set of homemade Ellsworth style hollowing tools and am using the Ellsworth tips in them and like them very much but if your method makes hollowing easier/quicker/maybe even safer I would gladly give it a try.
Thanks
Turning to keep warm in the Canadian North
Kirt
Steven Antonucci
holding you responsible :-)
Steve Antonucci
>after all, it was the piece you sent me (and my lack of attention) that did the job...
S
Re: holding you responsible :-)
Sean Troy
>Did you save the wood ????!!!!!
Steven Antonucci
Steve Antonucci
>The wood was fine...
It was only steel that broke. What is the RC hardness of Mesquite anyway? I figure it's at least 60-62?
S
Steven Antonucci
steve antonucci
>A better picture...
The rod is 5/8" with a hole in the middle and on the left side @ 45 degrees (or so).
There is a 10-32 set screw in the top to hold whatever is cutting....
Sean Troy
>Thats a softwood out here ! sean
