THE WOODRAT IS BACK!
Steady as she goes, Captain!
Keith Tompkins
Keith Tompkins
>Here is my version of Dominic's steady rest, shown during it's maiden voyage.
I made a couple of engineering changes to his design. Instead of a dado to hold each arm in place, I chose to include three ears on the frame; this allows two bolts to secure each arm. The idea was to better resist torsional twisting under load without weakening the structure.
The frame is birch plywood, two layers laminated in a home-built press. the arms are yellow birch, ripped to one inch, with a 3/8" spacer block glued at each end to form the groove.
I used angle iron to secure the monster to the bed, and to provide extra rigidity to the frame. I tried to match the paint of the General, and I found the green scooter wheels at K-mart.
I have since finished the permanent mounting fixture. I can lift the whole unit straight off the lathe without removing the tailstock, and two large knobs secure to the bed, one on each side.
Another set of arms is in the works, for securing up to a 16" piece. The knobs securing the arms will be moved to the back to avoid interfering with the wheels.
How does it work? Awesome! I hollowed this piece of holly 12" deep, no problem. The holly piece is part of a project.....special thanks to Dom and Mark Kauder for their input.
Re: Steady as she goes, Captain!
RonZ
>Great job Keith. We can tell who is the artist on this board. Who else would think of matching ring with color coordinated wheels. =o)
Bill Howatt
>Keith,
Very nice job. I really must get going on mine - but the longer I wait, the more ideas I get from you ambitious people!
Well done,
Bill
>Very nice looking rig Keith. Any problems reveled during the maiden "spin". ;~)
How did you mount the wheels?
Todd O.
Keith Tompkins
Keith Tompkins
>HI Todd, no ,I didn't encounter any problems during the first use. The bugs were worked out by Dominic and others before I made mine. I used 8 mm allen head bolts to secure the wheels. A spacer between the bearings of each wheel keeps the pressure fromcollapsing the wheel. A washer behind each wheel gives clearance. Thanks, Keith
Keith Tompkins
Keith Tompkins
>Thanks Ron, now go ahead, post your best artist's photo! lol, Keith
Keith Tompkins
Keith Tompkins
>Thanks Bill, go for it , 40 bucks, couple of nights work......fun project.
Mark Kauder, Phenix City, AL
>Very Nice, Keith.
Did you find that you had to true up the wheels at all?
Mark
Keith Tompkins
Keith Tompkins
>HI Mark, they run pretty true....I may touch them up a bit later. A spacer between the bearings avoids crushing the plastic "hub" in the center of the wheel; the wheels don't distort when the bolts are tightened. Thanks, Keith
Wow! Looks great!
Dominic Greco in Wet! Richboro PA
>Keith,
I really like the modifications you've made to the design. Especially the clamp block mechanism. That is just what I should have done.
Plus, you can't beat the color coordination!
See ya around,
Dominic
Keith Tompkins
Re: Wow! Looks great!
Keith Tompkins
>Thanks Dominic, your post came at just the right time......I have finished the base using similar knobs to the ones I used on the arms. The thing is rock solid. I wanted it to look like an accessory that came with the lathe. The green wheels were a bonus.....thanks for your help, Keith
David Eaves
>Excellent... great device. You finished it well too, I like how it matches the lathe. When I get the time one day I will have to make a hybrid of all of them for my lathe, it sure would be useful.
Thanks to everyone who has contributed to this design.
David
Keith Tompkins
Keith Tompkins
>Hi David, thanks. I needed the steady , and dom posted his just at the right time. I wanted the tool to look professional, as one turner or another is always dropping by......plus it matches my lathe. Note that Dominic used red wheels for his Jet!
