Have a question? Ask Woody!
Car Wax on a Lacquer Finish?
Mark Kauder, Phenix City, AL
>I know you all are going to tell me I can't, so I want to know why.
If I finish a bowl with a completely smooth - glassy, just like a new car, Lacquer finish, then why can't I use a car wax on top of it?
I know not to used silicon based wax on my TS, so the the silicon does not contaminate bare wood. But why not on finished wood?
In truth, I was going to use some Rennassiance wax on it, but I am out, and Craft USA ran out at the Woodworking Show in Atlanta, before I could buy some more.
Thanks
Re: Car Wax on a Lacquer Finish?
Kirt
>Mark I'll carefully wade in here to say that I also use car finishes(Meguires) on my work ,when I purchased them the gentleman at the counter asked what type of "classic car" I was restoring- I figured if this stuff was good enough for the pros to use restoring classic cars then surely it was good enough for my turning needs.. After applying laquer I use Meguires #2 and #7 in that order then off to the Beal Buffing wheels I use the white diamond( I skip the tripoli as I feel it is to coarse at this stage) then caranuba wax to complete the finish.I must say the response to my finishes since I started using the Meguires products have been absolutely positive for my "artisctic stuff" .I would not recommend it for a salad bowl!
Dont know if this helps but I figure the only way you will really know is try it and see for yourself, you might be suprised!
Turning to keep warm in the Canadian North
Kirt
Russ Fairfield
>If you use the automotive wax now, come back next summer and tell us that it was the right thing to do. It isn't the deliberate use that can cause problems, it is the contamination from your fingers, and most likely from something that you won't remember touching.
Why not go to the local Home Depot and buy a can of the Minwax Finishing Wax. It isn't Renaissance, but it is a good quality wax that will never cause a problem. You might even discover that you like it.
Joel Hunnicutt
>I've used beal carnuba wax on some lacquer finished bowls. I couldn't see allot of difference, but it had a nice "feel". I haven't figured out what's so special about Renessance (sp?) wax. I got Bill Baumbeck to send me a sample with some pens last fall and I couldn't see any advantage over other waxes. Seems like I recall a previous thread where someone said that Johnsons is also a microcrystaline wax.
Sam Simpson
>Hi Y'all,
Mark, I'm with you on this one. I can't think of any reason not to use car wax over lacquer. In Fact, I specify it on some work. I recently French polished a Gentleman's bathroom and instead of beeswax or carnuba wax, which we considered might be too susceptible to heat and moisture, we used "Turtle wax" (Brand name,, no turtles died in this operation :)
I'm not at all sure what the confusion is about contamination? These waxes are polymerized products, they might contain some silica, but not silicon. There are some car care products that do contain silicon, but they are liquid preparations for dashboards and the like. I don't think that is what you are talking about.
If you are still in doubt, post the product name and the list of contents from the label (if available) and I will try to be more specific.
Regards Sam Simpson.
>Mark
The only problem I've had with Car wax's is that they dry white until buffed. If you have any defects or pores that aren't filled in they fill these and you can't get the color out without using mineral spirits which removes the wax and you have to start all over.
I use Johnsons floor wax. It's inexpensive, hard and has a good feel.
Joe P
>I tried using just Minwax Finishing Wax on a couple of bowls and the finish is outstanding, I just don't know if it will hold up. Does anyone else have any experiance with this method.
