superior steel for lathe tools
Bill Tindall, E. TN
>Over on the quiet side we have been evaluating some modern tools steels for chisels and plane irons. Some lathe tools have been fabricated from one of these steels and this post describes some results. The steel is CPM 3V and its attributes are surperior wear, astonishing toughness and fine grain structure which enables it to be shaprened as well as any steel.
We have made both skews and scrapers from this steel.
Scrapers: Scraper steel must produce a durable wire edge. 3V excells in this regard. In fact the wire edge is so tenacious that it can be a problem when sharpening things like chisels and plane irons. Scrapers prepared from 3V cut as fast as a very sharp gouge and the edge holds up will.
Skews: A skew must take a very keen edge and hold it. Furthermore, if the steel is not tough, the fine point of the skew is subject to breaking. 3V is considerably more wear resistant than M2 and even at Rockwell 61-62 it will bend but not fracture. The high vanadium(high wear) steels used for gouges are impractical for skews because they are too brittle. Severe catches have bent the fine tip of a 3V skew sharpened at 25 degrees, but not broken the tip. It takes a thumping catch to even bend this steel. So, the properties of toughness, wear resistance and ability to take a keen edge makes 3V ideal for skews.
These tool types are very easy to grind out of readily available retangular bar stock. A skew will cost $10-20 depending on size. Tips on fabrication can be found in our previous posts on hand tool side. Perhaps this post will encourage some company to eventually offer tools from this steel. Bill Tindall and Phil Smith
Re: superior steel for lathe tools
You have just discovered Jerry Glaser's tools!! *LINK*
Russ Fairfield
>These folks are just discovering something that has been known in the woodturning world for a long time - a hign Vanadium tool steel makes an excellent tool. If you have been following any of the messages refering to Jerry Glaser's turning tools, you will find a lot of woodturnwers who are confirming this. Jerry Glaser has been using these steels for making turning tools for at least 20-years that I know of.
If a 3% Vanadium (CPM-3) makes a good turning tool, then 10% Vanadium as in the CPM-10 (AISI A-11) is even better; and that is what Glaser has been using. Some of his new tools are a CPM-15 with 15% Vanadium.
The CPM-3 is a new steel with less Vanadium (3%) and that results in a lower cost. There is always a sacrifice, and in this case there is some reduction in its resistance to wear.
You can check the properties and metallurgy at the link to the Crucible Steel data sheets.
Crucible Steel - data sheets
must disagree, experiment proposed
Bill Tindall, E. TN
>Mount you Glasser, or other high vanadium gouge(or M2 for that matter), in a sturdy vise, and, with a hefty hammer, bend it over 30 degrees. Oh, can't do that without it snapping? Well, then 3V has some attributes that higher vanadium steels don't(or any other tools steel we know about) and perhaps these attributes are significant, leading to the possibility that 3V isn't simply a cheap(inferior) version of 10V as you propose. The differences with 10V are toughness and wear resistance. 3V is much tougher and with wear resistance between M2 (traditional tool steel)and 10V. Now is the improvement in toughness worth the sacrifice in wear resistance? We propose that for a skew and scraper it may be. Skew tips won't break and wire scraper edges (burs) will form easier and last longer.
There is another issue that we have not evaluated. Some respected turners have claimed that the high vanadium steels do not take as fine an edge as carbon steel or M2. We don't know as we have not worked with 10V. However, 3V is considered a cutlery steel and it most certainly will take as fine an edge as any steel as proven in plane irons and chisels.
With luck we will inspire others to investigate this steel, as others have investigated this steel for plane irons, with favorable results. As a result of this greater experience with 3V we can come to a valid conclusion whether it offers improved performance.
Re: must disagree...
Lyn J. Mangiameli
>To take these in order:
1"Mount your Glasser, or other high vanadium gouge(or M2 for that matter), in a sturdy vise, and, with a hefty hammer, bend it over 30 degrees. Oh, can't do that without it snapping? Well, then 3V has some attributes that higher vanadium steels don't(or any other tools steel we know about) and perhaps these attributes are significant, leading to the possibility that 3V isn't simply a cheap(inferior) version of 10V as you propose. "
But Bill, you haven't demonstrated that these attributes do have any significance to turners. Frankly, your "experiment" seems meaningless to me in the context of woodturning. I have subjected Glaser gouges to some brutal punishment when roughing out large out of round blanks, and the gouge shafts have neither bent nor broken, just what I want in a good gouge.
2. "The differences with 10V are toughness and wear resistance. 3V is much tougher and with wear resistance between M2 (traditional tool steel)and 10V. Now is the improvement in toughness worth the sacrifice in wear resistance? We propose that for a skew and scraper it may be. Skew tips won't break and wire scraper edges (burs) will form easier and last longer."
I've used Glaser skews and scrapers as my primary tools of those types for over five years now. I've never had any of those tools, chip, break or bend. I form my scraper burrs with the Veritas scraping tool burnisher (i.e., fixed carbide rod) and find the burr retention to be easy to achieve with that tool, easy to control, and the life of that burr is outstanding compared to all other scrapers I own (including those using Tantung blades). I don't think you have conducted the comparisions to empirically state that 3V has shown any real world advantages compared to A11 and V-15.
3. "There is another issue that we have not evaluated. Some respected turners have claimed that the high vanadium steels do not take as fine an edge as carbon steel or M2. We don't know as we have not worked with 10V. However, 3V is considered a cutlery steel and it most certainly will take as fine an edge as any steel as proven in plane irons and chisels. "
I'm at fault for not providing a proper response to your private quiries on this question, but I shall make some comments now. I am so weary of those with no objective empirical evidence going around propogating and perpetuating such inaccurate information, that is largely a hold over from the early days of some manufacturers using inferior carbides for table saw blade teeth and router bit inserts. Furthermore, I find it amusing if not ludicrous that these assertions often come from the same individuals who find an edge right off an 80 grit wheel to suit them just fine.
As long as you are using a sufficiently hard sharpening abrasive (such as the diamonds you are fond of), any of the CPM steels can achieve an edge everybit as sharp as is achieved with Carbon and HSS.
As you know, handplane blades are regularly sharpened to a level of edge refinement which far surpasses any edge used by woodturners (with the possible exception of a handful of skew sharpening fanatics, including me). I regularly refine hand plane and bench chisel edges to .5 micron. I have worked with O1, A2 (both Cryoed and not), A11, CPM10, M2, M4, unspecified HSS, and laminated blue steel Japanese style blades. Used with very challenging woods with a top performing plane, I can discern no difference at all between them when freshly sharpened (some blades, of course, have longer edge retention). If the sharpened performance of these blades with such an extremely refined edge is indistinguishable, I have no doubt that such differences are no less indistinguishable with turning tools that are almost universally sharpened to a much less refined edge.
As an aside, Jerry Glaser also has made up some V-15 handplane blades for himself and has privately reported his satisfaction with them (and Jerry knows as much about hand tool steels as he does about turning tool steels).
4. "With luck we will inspire others to investigate this steel, as others have investigated this steel for plane irons, with favorable results. As a result of this greater experience with 3V we can come to a valid conclusion whether it offers improved performance."
Yes, I think this is a commendable desire and I greatly admire the experimentation and sharing of information you have provide to both hand tool users and woodturners. I am not surprised at all that CPM3V works well for hand tools (I would suspect it is exceptional for mortice chisels) and may prove a desirable steel for woodturning as well. However, there just isn't enough comparative information to determine for what woodturning tools it will be most appropriate. I suspect that it will be a desirable steel for skews and low bevel angle spindle gouges (where V-15, for example, is a bit too brittle and susceptible to chipping). It may also be good for narrow parting tools.
I do appreciate your enthusiasm for 3V, but I also am very familiar with the wide ranging metallurgical knowledge and depth of tool making experience possessed by Jerry Glaser. Jerry's decisions have been based not only on theorectical knowledge, but the feedback from hundreds if not thousands of tool owners. He is not wedded to any particular steel manufacturer or source, and continues to this day to keep up on the latest tool steel offerings, and engage in R&D. His decisions consistently have been sound based on my practical experience using and comparing tools.
Well said!!
Dominic Greco in Richboro PA
>Well spoken Lyn. I couldn't agree with you (and Russ) more.
I've been using my Glaser tools now for about 3 - 4 months and am astonished at the tools steels ability to resist wear. I have subjected both the 5/8" and 3/8" gouge to the nastiest, hardest woods I can find (Osage Orange, Hickory, & Rock Maple). And they have not been small blanks! Some were 15" in diameter and weighed 35 to 40 lbs! These gouges have withstood some serious "abuse" (if you can call it that).
IMHO Jerry's work in pioneering the use of these types of steels for use in lathe tools was downright inspired. Aside from that, he speaks my language! (At one time I thought of pursuing an advanced degree Metallurgy and Material Science. But because of time considerations, decided against it.)
See ya around,
My ugly mug
Dominic
to clarify a point that missed the mark
Bill Tindall, E. TN
>I must say that I was taken aback by the responses to date. Apparently my response to a statement by Russ has been interpreted as a criticism of Gasser tools. Not intended. I do want to respond at what seems like a perspective that something better is impossible.
Russ seemed to dismiss 3V as a lesser version of the higher vanadium steels. It was this statement that I was responding to. 3V was invented to be tougher, with the sacrifice of wear resistance, and companies are buying it for performance more than price(according to CPM folks). The proposed "experiment" only was intended to illustrate the difference between 3V and any other tool steels I am familiar with. This advantage has proven beneficial in better wearing tool dies(a commercial use, no wear by microchipping), robust knives(for example Hossom Knives), and in our hands mortise and dovetail chisels, and perhaps plane irons(see posts on Hand tool side). Now, the curious mind will ponder whether this advantage offers anything for turning tools.
Those that have acquired the experience where they never risk snapping the tip off a skew will not find any benefit in a 3V skew. I snapped the tip off a Sorby hitting a pin knot so I gained the experience of avoiding pin knots with this skew and the desire to improve this situation. 3V has provided me with an unbreakable skew with better wear resistance than M2, and I might add at a very low cost, $10-20 per tool. I risked posting the original information because I thought I might not be the only begining turner desiring these benefits.
Even experienced turners should consider the possibility that 3V's toughness might offer some advantages in burr formation and durability on a scraper. The key word here is consider, as I think that some of the criticism was dismisal with out much consideration. How do burrs fail in use? I am guessing by chipping, given their delicate nature. If so, 3V has a potential advantage, or maybe not. I have never seen anything like the tenacity of the wire edge 3V forms when sharpening. I am only suggesting that this property might be further investigated by persons who like to investigate things and who are better equipped than I to evaluate the results.
Let me close by restating our objectives in these steel posts. Some one from the tech staff of CPM called me yesterday to discuss what we were doing with these woodworking tools. They have received a number of inquiries and orders from people who have read the information we have published on making tools and these people are trying it themselves. That is our only objective, to encourage people who want to, to look at possibilites of making some of their tools. To this end we have provided information on steel, fabrication, and heat treating. Apparently we have encouraged some people to try what we have done, and with luck they will improve upon it. I do not accept that the "best" has already been discovered about anything.
PS we do not sell anything, nor intend to.
Afew small points
Bob Hackett
>I have seen Glaser gouges that have snapped off,three of them from our club alone.At better than $100 a piece I expected them to be alittle more durable in the hands of beginners,technique aside.
The Glaser pricetag is also a factor for some people,especially those who are not quite sure about thier sharpening skills or have yet to decide on the optimum profile for thier style of turning.
The major advantage that Bill`s research offers is the option to try somthing else,on your own,as opposed to just turning with what is offered in the catalogs.3V can be purchased,worked,and made into custom fit tools by most any WWer with average skills,at a cost of 20-30% of what Glaser sells his limited line of tools tools for.This puts having an almost unlimited assortment of high quality,custom made tools in just about everyone`s reach.Something that would be impossible buying from a catalog.
Bill has also done in depth research that allows WWers to maintain these and other "exotic" steels with a minimum of false starts and wasted funds.I for one look forward to his posts and have put much of his research to work in my shop.
Thanks Bill,you`ve saved me alot of both time and money.I appreciate all your hard work and your willingness to share it.
Mainely,Bob
Re: Afew small points
Dave Peebles Lyons,Ohio
>Hello Bob,
Can you give some details on how they broke off the Glaser gouges. I find this to be almost unbelievable. Not that I don't believe you. :)
But I find it surprising that you could snap off the end of any gouge (regardless of brand) unless you are doing something very, very wrong. Or there were some defects in the metal of the gouge.
Thanks,
Dave
Phil Smith
>Our choice of steel was a pragmatic choice based on our research of data available on the internet and from direct contact with Crucible Steel. We were well aware of the Glaser tools and my initial inclination was to use one of the high vanadium steels such as CPM 10 V or 15V for our hand tools (chisels, plane irons etc.) But after talking with crucible steel and some of the knife makers we chose the CPM 3V for it's combination of toughness and wear resistance for our chisel and plane iron application.
Once committed to making hand tools adding a couple of LOW COST lathe tools was a logical extension. The lathe tools we choose were tools where the combination of toughness and wear resistance would be of value - skews and scrapers.
The toughness of the skew is dramatic. As a new turner I still get nasty catches from time to time. This week I got a catch that would have broken the tip of my M 2 skew off based on past experience. With the CPM 3V skew the only damage was a VERY small bend in the tip. Approximately 1/64 inch of the tip was bent 90 deg. Note the tip did not break.
The bottom line for me is that with relatively simple tools that are readily available in many home shops you can fabricate high performance cutting tools from lathe tools to hand tools. The techniques we used for CPM 3V should also work for Crucible's particle M 4 as well as for CPM 10V and CPM 15V.
Kirt
>Curious, you said it "bent the tip instead of breaking it off" sounds to me that you still have a damaged tool that will require almost as much if not as much re-working to make it usefull again. I'm no steel expert and am only willing to wade as deep as my ankles on the subject as I fear I would drown if I got in to far. Other posts have mentioned tools such as Glasser that have snapped in half etc.. I own a boxed set of really cheap turning tools that were given to me when I bought my lathe-they carry the Canadian Tire label and compared to my "high end" turning tools they are crap but I have been in some very serious catches with them and have yet to break one in half (even when used in a manner I knew was "risky") I find it difficult(but not impossible just difficult OK!) to imagine how a turning tool could snap in half unless it was being used improperly-and that would not make it the fault of the tool but that of the user,I am not saying that faulty tools dont exist and I sure hope I never prove to myself that a tool can be snapped while turning! I am however curious as I have mentioned a "bent" tool still requires re-working so what is the benefit provided by having a tool that will bend when caught to one that chips if they both will require attention to get them back to usefullness??(other than eye safety and we all know we should be wearing proper eye protection at all times in the shop so that negates that argument -or at least it does for me!)
Hey as I said I am no expert just curious.
Turning to keep warm in the Canadian North
Kirt
Gouge failures
Bob Hackett
>The gouges were all bowl gouges,two were the red handle type and one was blue handled.All the gouges snapped off near or past the halfway point of the flute length.I saw a slightly irregular area on the surface of one break,otherwise the breaks were clean.
The breaks all being that far back seem to point to extreme overhang past the toolrest.
Amazingly enough one person broke two gouges.He`s an experienced turner with(how do I say this)rather unorthodox technique.He doesn`t demo at meetings anymore,we have too many retired folks as members and we were calling 911 and doing CPR too often.His nickname is WHOA!;^)
Mainely,Bob
PS
Bob Hackett
>I have encountered voids in bars of Tantung while making turning tools.I stopped using Tantung for anything other than small tools because of this.
Particle steels did not seem to have the impact resistance of other tool steels and I`m going to assume this contributed to the breaks in the gouges I saw.The same turner who broke two of the Glasers had bent some Sorbys and Henry Taylors before.Prior to the Glaser tools the only tool he actually broke was a diamond cross sectioned parting tool.If memory serves me,he had it buried almost to the handle while coring a bowl blank when it caught and snapped in two nearly amputating a finger.Low marks for technique,high scores for determination.
Mainely,Bob
Thanks Bob
>Hi Bob,
I love that nickname, :) Thanks for the details.
Best,
Dave
Re: to clarify a point that missed the mark
Dane Lance
>I've read this thread with great interest. I'm by no means a metalurgist (but I did stay at Holiday Inn last night...nyuk nyuk nyuk)....
I perused the CPM site some time back in search of pricing for some of the various V steel blanks in order to make some tools for myself. I was very much interested in the various ratings and the components of the various steels.
What I can decipher from the V series of steels, in very loose terms (and this is the key...very loose terms), is that the vanadium content creates a trade off. The higher the content, the more wear resistent there is, but the more brittle it is and vice versa.
The question that comes to mind when considering the V steels for turning tools (or any blade) is to what degree do we need toughness, or, lack of brittleness. Obviously, we all want any blade to hold an edge as long as possible.
To truely rate the merits of the various V steels for specific applications is going to require knowledge and/or figures for the amount of force applied to a tool edge. This will help us determine the best V steel for the application. Obviously, Jerry Glaser has done quite well here. The V15 gouges are nothing short of spectacular. In my uneducated guestimation though, I would suspect a small diameter V15 tool might be broken easily. In the sizes that we find the V15 gouges though, I doubt this represents much of an issue.
I'm quite sure 3V steel would present an excellent steel for a lot of edged tools, enough that it might warrant a "mid grade" (for lack of better term) option for those not wanting to drop the cash for V15 tools. I know of at least one manufacturer that is doing just that for their line of turning tools. Basic and advanced CPM steels to provide various degrees of edge holding....all with the appropriate price increases for each as well.
