Is there a secert incantation I need to utter...
Ron Sardo in PA
>Is there a secert incantation I need to utter to make a jam chuck work?
I'm working on a lid for a small box. I turned a jam chuck with tappered sides so I can turn both sides. But I must be missing something because the lid will not stay in place.
Did I just hear someone wisper Vaccum Chuck!
Re: Is there a secert incantation I need to utter...
>Ron
When I make a jam chuck it is only tapered about 1 or 2 degrees. Just enought to make it fit. If your lid is still loose try putting some shim material on the chuck. I use either tissue paper or paper towels. Every now and then I have to use 16 oz leather. We all have our bad days.
One day I was complaining about a jam chuck and friend who is an instrument repairman said to wrap in in thread and soak the thread in glue. This is how they fix some Clarinets. It worked great.
Ron Sardo in PA
>Maybe that's my problem. My tapers are a little more that 1 or 2 degrees more like 6 to 8. Thanks John!
John Trant (aka Boxes-n-Bowls)
>In addition to John's excellent comments, I would like to add a few of my own:
1) Make sure your lid bottoms out on something (typically the rim of the lid flush against a ledge of the jam chuck).
2) Usually, my jam chucks are too tight so that I have a hard time removing the lid. Often, a couple of knocks against the jam chuck sets up enough vibration to loosen the lid. If not, drill a hole through the chuck and use a tommy bar to gently knock it off
3) If the jam chuck is slightly too loose, add a little bit of moisture to the joint and it will tighten right up. In my turning club, we call that "tounge oil" (pun intended).
John
Ron Sardo in PA
>The inside of the lid is concave with the outside convex. Will I need to make two jam chucks to match each side or can I do the inside first then flipping it to then do the outside last. I don't think much wood will bottom out this way.
Richard Allen
YES there is a secert incantation
Richard Allen
>Hi Ron
Please keep this quiet but the magic phrase is:
Comutra domlis fanutle riggius roggius reggius comeatrla
You have to say that three times slowly while turning in a anti-clockwise circle starting by facing Stockholm and finish by facing Raku having made three complete revolution, one while looking up to the heavens, one while looking down to mother earth and the third with your eyes closed looking inward.
This all assumes that the detail gouge you have in your hand was blessed.
The typical blessing is done by holding the tool in the horizontal position while rotating the tool with one hand clockwise and sprinkling an exotic wood sanding dust on the steel while chanting:
"Spirt of the turner bless this tool with the steady sure hands of the master."
It helps if you think of a particular woodturner as "the Master".
Naturally this ceremony should be done in the dark of a full moon while facing your lathe.
Richard
P. S. Naturaly this is only good for jam chucking boxes.
RonZ
>While waving your skew to and fro, the incantation to utter starts with this mutter: Bread, bread, peanut butter. Spirits make this jam CHUCK!
Sorry, I couldn't resists. =o)
Paul Norton
>The following incantation usually works well for me:
!!ck it!
If that fails I use masking tape to tighten the fit.
Keith Tompkins
Keith Tompkins
>Hi Ron, remember,when sizing the jam chuck, if you remove a siteenth, you are really removing an eighth, in other words, you are removing twice as much material as you would expect.
It is very easy to remove too much material because of this.
RonZ
>Besides all the good advice you're getting I use water depending on how off it is. It has worked so well that I have had trouble getting the thing off afterwards.
Loose Tenon
>Ron,
John gave you some good advice.
Are the shoulders of your lid perfectly parallel? If not, the lid will pop off the jam chuck. Try using a softer wood for the jam chuck; I like mahogany or straight grained, old growth fir. The softer wood gives a little. I don't taper my jam chucks I just make the lid fit a little tighter. You might also try melting some bees wax on the jam chuck spigot and push the lid on quick before it dries.
Good Luck, Loose Tenon
LICK IT? I'm shocked...
Rodney Jenkins
>at the depths you woodturners sink to.
Ron Sardo in PA
>Soft wood.... I was using maple. I heard the trick about beeswax. I'll have give it a try.
Re: YES there is a secert incantation
Peter Teubel
>Hmmmm. Personally, I use the charm of making:
"Ahnaal nathrac orvas bethude doch nell de envay."
....shades of Excaliber
Dick Jacobs
>Borrowing from my grandmother, try this: "Oy vay! Jam already!"
Mine usually looks something like this...
John Cotten, Harrodsburg, KY
>()*#(@*%(@#*^%+@#%@#*%^@#*&$&^$&@_(&!#+!#@_!#*^!!!
Seems to work every time, although the kids hid and the dog won't even look at me afterwards.
