Bore before or after
Ron, Neosho, Wi.
>I'm making some stools. I'm thinking that if I bore the holes in the legs for the rungs when the stock is still square, ie. right out of the planer getting the holes at right angles to one another should be a piece of cake. However, would I have a lot of chipping out as the gouge passed over the holes when I turn them? I'm using hardwoods: birch, maple, oak, etc. I know I can make a jig to use for boring after turning, I'd just like to remove another step if possible.Thanks in advance for any opinions.
Re: Bore before or after
Stuart Johnson
>Drill the holes and then plug them (don't glue). After your turnings is completed pull out the plug.
>Ron
I drill them after turning. I use a brace and bit with an extension. This allows me to eyeball it quite accurately. I would think you could do the same thing with a power drill and extension.
If you make a V block for your drill press and calculate the angles accurately you could simply drill it on the drill press.
When I built some chairs years ago I had all kinds of jigs to hold everything accurately. Then I got into green woodworking when I took a Windsor chair class from Curtiss Buchannan. No more jigs, I just do it the old way. It works well and is much more fun. John Alexander's book on green wood chairs is excellent for instruction.
jim reasoner
>On the stool I made for my workbench, I drilled the holes before turning the legs. For my limited woodworking skills, drilling the holes at an angle on a flat surface is much, much easier. The suggestion for drilling first and putting plugs in is a good idea if you can get a good fit for the turning process and easy to remove when you are through. Another thing I did that worked out well was to drill holes in the seat all the way through, put the legs in the holes with a slot cut crosswise in the top then pound in a good hardwood wedge. The legs have not gotten loose at all after 6 years.
