Linseed Oil & Deft
George Van
>Can Deft clear wood finish be applied over boiled linseed oil?
I have a couple of pieces I would like to apply the Deft to that are already treated with boiled linseed oil if they are compatable.
Thanks, George
Linseed Oil & Deft
George Van
Thanks, George
Yes, but.....
Russ Fairfield
>Even though they take great care to not identify it as such anywhere on the can or in their literature, Deft Clear Wood Finish is a nitrocellulose lacquer that is formulated for brush application. As such, it can be put over the Boiled Linseed Oil, or any other oil based finish, IF....
1. The oil finish is totally cured, and the first coat is applied with a brush, or
2. A barrier coat of shellac is put between the oil finish and the lacquer.
Whenever I have done this, I have NOT used the shellac, but put the Deft or other lacquer directly over the Oil finish. But, the oil finish has to be fully cured. This can be tested by buffing the surface of the finish with 0000-steel wool. If it comes off as a white powder that can be removed from the steel wool by slapping it on the edge of the workbench, it is cured. If it doesn't, it isn't.
After buffing the surface of the oil finish, the first coat of lacquer is brushed on and immediately wiped off until it is clean and dry. This allows the thinners in the lacquer to act as a surface cleaner to remove any of the remaining oils from the previous finish, and it primes and seals the oil finish. Subsequent lacquer coats can then be applied by either brush or spray.
Re: Linseed Oil & Deft
George Van
>Thanks Russ,
I will get out some steel wool and give it the test!
George
Would plain laquer thinner do the same?
Joe Pack
Yes, but.....
Russ Fairfield
>If you used lacquer thinner by itself, there will always be a risk of not getting the surface thoroughly cleaned, contaminated by finger oils or perspiration, or any uncured oil rising to the surface before the first coat of lacquer can be applied. It only takes one little spot to ruin a good finish.
Using the lacquer is a one-step solution to cleaning the surface and putting a barrier coat over the oil at the same time. This reduces the risk of adhesion problems.
The best solution is to not put lacquer on top of an oil finish at all. That eliminates all risk of adhesion problems. Some folks claim that the oil has to be used on the bare wood to accent the grain. My experience is that the lacquer does a good enough job of accenting the grain by itself that the oil is unnecessary.
Thanks Russ
Joe Pack
