Grinding Wheels - When are they worn out?
Mark Kauder, Phenix City, AL
>I am looking for the opinion of my fellow WC Turners here.
When do you replace your Grinding wheels? I have pink wheels that I have been using for many years. They were first on my cheap Harbor Freight 3400rpm grinder, and now on my self-made variable speed grinder. I usually sharpen at under 1000rpm (virually no sparks - almost like grinding on an Olde Tyme Treddle Wheel). Anyway, they started out as 6" wheels, and are now down to just under 5". I have considered going to 8" wheels (as much for the additional width as anything) thoug the additional cost over the 6" wheels is a bummer.
I am not so sure the the tighter radius on the worn wheel is all that much of an issue in sharpening, but?????
I will be at the Woodworking Show this weekend, and thought I might pick up a new wheel or two.
Opinions Folks??
Feel free to comment on Grit, brand, color, etc.
Thanks,
Mark
Re: Grinding Wheels - When are they worn out?
Re: Grinding Wheels - When are they worn out? *LINK*
Sean Troy
>I use 1"x8" wheels on a slow speed grinder. Once I lose about an inch, I replace them. I,m just picky that way. Sean
http://www.arizonawoodturners.org
>Sean,
Where are you in Arizona? In the Valley?
I grew up in Phoenix/Glendale, my parents and brothers still live there. I might get out there in March on my way to a business conference.
Mark
>Mark
Mine were down to 4 1/2" before I pulled it off my good grinder. I now have 8" I don't remember noticeing a difference in cutting action when I changed. I mostly changed because I wanted wider wheels.
Try ENCO or www.travers.com for wheels that are much less expensive.
Wally Dickerman at Green Valley, Az.
>Mark, Kestrel Creek website has some good information on grinding wheels from some experts. Might be worth a read.
Wally
http://www.kestrelcreek.com/toc.htm?id=26&cat=review
Sean Troy
>Hey Mark, I,m in Gilbert. Buy all means let me know when your out this way and we'll get together, Sean
Jennifer@Indy.USA
>Hi Mark,
I replaced my 6" wheels when mine went under 5"....with the Wolverine jig system there comes a point when, in order to get the correct angle on the grind, I was teetering on the center/below center line of the wheel and it got kind of scary.
I opted for the Delta 8" VS grinder when I replaced them. The higher price of the wheels is a drag....but that's just the way it is : (
Jennifer
Richard Allen
Richard Allen
>Hi Mark
I went through the same thing a whike back. I went with the 8". The wider wheel is nice for larger tools (1/2" bowl gouge and larger in my case).
Becasue the hollow grind is different I found I had to do quite a bit of grinding to establish the new bevel.
I also noticed that the bevel on my larger tools (5/8" bowl gouges and larger tools) was easier to work with at the lathe. I was unable to detect any difference in the usablity of my 1/2" bowl gouges and smalle tools.
The 8" wheels I bought cam attached to a dual speed grinder. I found that when I sharpen at the higher speed the wheels need to be dressed less often.
Thanks
Richard
Peter Teubel
>I guess I'm MORE picky (grin). I replace them after they wear down 3/4". Beyond that, the grinds on my tools change. I like my tools consistent. Generally, I go thru two wheels every 6 to 8 months.
Doug Leite
>Wally,
Very good article on grinding wheels. Everyone should read it. Thanks for posting the link.
Aloha
Doug
Keith Tompkins
Keith Tompkins
>Hi again, I use 8" pink and grey wheels. I like the additional width also.
I may be one of the few who prefer a high-speed grinder. I think it's faster,smoother, and produces a finer finish. the secret is a light touch....I have no problem using the grey wheels.
I would use an 8" wheel until it wore about an inch.
Russ Fairfield
>Am I the only one who uses an 8" wheel until it is so small that the guard keeps me from getting at it with the tool? That's about 5-1/2" diameter on my grinder. And, I have been known to remove the guard to get another inch off of it.
Grinding Wheels - When are they worn out? Thanks
>Well, I guess the general drift is - there is no reason to change my current wheels, if I don't want to, and they are doing the job - which they are.
Thanks all, this has been a good thread for me. Wally - thanks for the pointer to Kestrel Creek - I had not been there is guite a while, good site, and great article.
Thanks
Mark
Bill Howatt
>You might be with the 8" wheel but my originally 6" wheel is down to 4+" and I'm starting to hit the grinder motor.
Hmmm, with a belt drive and a shaft to mount the wheel on I'd be good for another...
Bill
