200+ woodworking book reviews
Tool Gloat...
Tool Gloat...
Tool Gloat...
Peter Teubel
>I just picked up my new 2hp Jet 20" bandsaw today...all 500 lbs of it. Took about an hour to unload it, move it into position, and set it up. Not easy by yourself!
The blade it came with shouldn't be called a blade. While it LOOKED like a blade, had teeth like a blade, but it was so dull that I had to replace it after trying to cut up the shipping crate. I doubt I could have cut my finger with it.
I finally got to use some of the 250' 5/8" blade coil I've had sitting around for a few months. Welded up a band and installed it. Now THAT was a real blade. I proceeded to cut a few 12" thick blanks. MAN, this baby has some power! And smooth with a capitol "S". No vibration whatsoever. It's so nice to be able to raise and lower the blade guide without having to adjust the bearings.
One poor design feature is the adjustment bolts for the lower blade guide. Who was the freakin' Einstein who designed that?! You have to tilt the table just to get AT the bolts. Even then you have to be a contortionist to get a wrench on them. I solved that problem immediately by drilling two holes thru the table right above them so a long allen wrench can now be used ABOVE the table to access them.
The foot brake is a simple affair consisting of a leather lined metal strap that wraps around the lower wheel shaft. There's also a micro-switch that shuts off the saw when the brake is applied.
Overall, I am very happy with it. Just in time, too. I just got a line on a truckload of ash this afternoon!
Re: Tool Gloat...
Same lower guides as Jet 18"
Dominic Greco in Richboro PA
>You wrote:
"One poor design feature is the adjustment bolts for the lower blade guide. Who was the freakin' Einstein who designed that?! You have to tilt the table just to get AT the bolts. Even then you have to be a contortionist to get a wrench on them"
Boy! Do I hear you on that! My new Jet 18" Bandsaw has the same problem! Other than that "design feature" I love this bandsaw. And I totally agree with your comment about the stock blade. Joel Hunnicutt told me to trash mine as soon as I unpack it. And he was definitely right about that. It wouldn't cut soft butter. I immediately installed a Timberwolf blade.
See ya,
Dominic
Re: Tool Gloat...
Keith Tompkins
Re: Tool Gloat...
Keith Tompkins
>Awesome! I want to supplement my old Rockwell 14" with a new saw. I tried my friend's big Grizzley. I was sceptical, but I was very impressed after using it. have fun!
Re: Tool Gloat...
Tony Reynolds
Re: Tool Gloat...
Tony Reynolds
>Hi Keith,
I've had the G0514 19" Grizzly for about 6 months now. I've found it to be a great saw. Super value.
Tony
Re: Tool Gloat...
Re: Same lower guides as Jet 18"
Peter Teubel
>Seriously, just drill two holes thru the top of the table so you can access the screws from the top. The holes won't affect anything. I used to have a 1973 Chrysler Imperial (just sold it last year). All the spark plugs had to be accessed from underneath the car. I finally just cut some 1" holes thru the fender well. Straight shot to all but one of the plugs. I used rubber grommets to seal the holes. Worked so good, others in my car club did the same.
