Jet lathe question
Jet lathe question
Jet lathe question
keith zimmerman, Normal IL
>Question about my new Jet VS mini. How do I remove the live center from the tailstock?
The rod that came with the lathe doesn't seem to be long enough to push it out of the spindle.
Any thoughts will be greatly appreciated.
keithz
Re: Jet lathe question
Mark Kauder, Phenix City, AL
>Keith,
Turn the tailstock handle as though you were moving it away from the headstock, eventually it will self eject the live center.
Mark
Jim Rutten
>Keith,
Don't know if this is the case, but there is a shoulder in there that you have to get past in order to knock the center out of the headstock. You just have to feel around until you get right in the middle. If that doesn't work, Woodcraft has their "tommy bars" on sale this month.
Charles Bjorgen
>You don't want to use the knockout bar on the revolving center because you'll probably knock out the point from the revolving center unit. I forgot about this myself last weekend during cleanup after one of my local club's hands-on sessions. Using a magnet, I finally found the point embedded down below the ways of the lathe but meanwhile, I spent considerable time sifting through lots of shavings looking for the point.
As others have suggested, the unit is self-ejecting by winding the quill back into the tailstock. If this doesn't work, you may need to realign the groove in the quill with the locking screw. My first lathe, a Delta Midi, worked the same way.
Thanks
>the self ejection process worked.
Thanks all
