REAL MILK PAINT
Apologies to whoever I told that mahogany*pix*..>>
RonZ
>..>> mahogony is boring. Here in Israel you get your lumber bulk. So sometimes you can get some nice surprises without being charged more. This looked like a boring piece but when I turned it, it showed a real nice tiger type pattern. Good thing it wasn't at some of the stores in the US where its planed and precut and labled tiger mahogony costing 5-10 times as much. The bowl/platter is about 9 1/2" in diameter and about 2" high. The finish is Mylands friction polish and carnauba wax. I really couldn't get a good side view to show the profile
Re: Apologies to whoever I told that mahogany*pix*..>>
Mike Schwing from Maryland
>Very pretty! I'd never ever ever say mahogany is boring. Around here we'd call that "ribbon stripe" mahogany.
Question for you - I really like your finish and have never been able to get anywhere near that with the mylands friction polish. It just doesn't seem to build for me, but instead winds up streaking. Any idea what I do wrong? I gave up on it as unworkable but obviously, from your work, it is far from it.
Great job.
Very Nice!
Jorge Casta�eda ~ East Penobscot Bay
David Eaves
>Wow, great bowl your shape really shows the lovely stipes off. Excellent finish too.
David
Most Excellant!
Ron Sardo from PA
>Really Nice Ron!.
Thanks guys. Mike, the way I do the finish ...>>
RonZ
>..>> I sand starting with 180, 220, 320, 400 using a sanding wax in between every grit except 320 and 400. I then use cellulose sanding sealer and de-nib with 400 sand paper. I apply a second coat of s.s. and follow with 0000 steel wool. Now it's time for the friction polish. I re-use my rags and keep them damp so it kind of works like a rubber in french polishing. I apply the 1st coat while the lathe is off to make sure I get an even coat. Then I turn the lath on at fairly fast RPMs and use the applicating rag to spead the finish. It needs to heat up in order for the finish to set. If you have good light overhead, when you move the cloth from side to side briskly [this is the 'friction' part of the polish] you'll see the rings disappear. I then [thanks to Russ] burnish it with postal brown wrapping paper instead of shavings. Next, I keep the cloth folded up and put some f.p. on and wipe while the lathe is on fairly fast and repeat. This is the 'high build' part of the friction polish. I then use a sweat shirt cloth on the soft side to give the f.p. a final buffing. I then apply a thin layer of carnauba wax and melt it in using the rough side of the cloth with the lathe going fast. I use the same cloth over and over again so this might add character. Once the wax is melted in and there are no rings present, I give a final buff with the soft side of the cloth.
By the way, while it might seem like a long time, I think this is the best and fastest finish.
If I wasn't clear or if you need more information, don't hesitate to e-mail.
great explanation, thanks!
>I'll have to turn some scrap and give a shot. Thank you. I think it was very clear.
