THE WOODRAT IS BACK!
Looking for Lathe, need advice
Georg Waldhof
>I need as much and any advice as anyone want's to give out on purchasing a new or used lathe.
I have been looking at the used market for price, quality and aesthetic reasons (I like the way the old ones look). Also, I'm hoping to keep cost down. It will be hard to justify $3-4K on a new lathe so . . .
Lathes I've considered are the PM 90, Oliver 167, and Delta HD variable speed. I'm open to other suggestions/advice. Would love to have a harrison union graduate but I also know what they cost.
I figure I want a 1.5" spindle with 1 to 2 hp motor - phase is somewhat secondary since I can always set up a converter if the price is right. Also, I'm thinking along the lines of a gap-bed lathe with at least 12'swing over the bed and 17" + over the gap. Would prefer 40"+ between centers but could get by on 38". Oh, and an indexing feature would be very useful.
Anyway, what does anyone suggest that meets or exceeds these parameters?
Someone has offered me an older Delta HD variable speed (not sure of the model number or serial number) that seems to fulfil most of this - however shipping is going to cost and he's asking about $1200 for it. The only flaw is that it needs an indexing pulley - apparently someone changed the original to a plain pulley. It also is a 1.5hp 1ph motor (new).
I'm open to suggestions and appreciate your advice.
G
Re: Looking for Lathe, need advice
Peter Teubel
>Do you want to turn or fix/restore machinery? If you want to turn, I would suggest a Nova DVR. Throw it on a stand or bench and start turning. Completely self-contained and with bed extensions, more than enough length for virtually any application.
Larry
>I agree with Peter except that I would avoid the DVR and go with the Nova 3000. Much less expensive and superior IMHO.
Keith Tompkins
Keith Tompkins
>Hi Georg, Sounds like you are a candidate for a General. 20" swing, variable speed, 36" or more between centers with extentions available if you need more. Massive, classic style machine. Mine was under 3K delivered. 2HP is standard, and more than sufficient. Asmooth running lathe!
Guy
>How about a Powermatic 3520A, price is real good from Osolnik, solid, heavy and it comes complete out of the box. I just picked up a Vicmarc VL300, real stout, adding my own motor and stand, good price for the naked model. The Nova 3000 is really nice, I'm selling mine though cuz I have no room for the Nova and the Vic. The Vic is about three times the weight of the Nova but with both you can add basically whatever motor you want and with the Nova you can add bed extensions to your heart's delite. Take it easy, Guy
Norm Buchanan
>I go along with Peter the Nova DVR is a good bet at $1800 even better with optional outboard tool rest.
Fog Tanner
>Georg, I went through similar problems. My first lathe was the variable speed Delta 16" steel bed, which was to be a lifetime machine. I got interested in offcenter and eccentric turnings where the offcenter swing exceeds the 16" swing. I still love the Delta for spindle and smaller work, its still a good machine.
I started looking at larger machines ,like you, not wanting to spend a large amount on another lathe. I looked at the Powermatics, but got turned off when I called the factory and found they were being made in China. That had me looking at the 16" and 20" Oneways. The 16" with the outboard attachment. About that time I went to the Texas Turn or Two and got to see a Vicmarc 300.
After kicking the tires and looking at it it and feeling how smooth the talistock and banjo moved, I was pretty much sold. The price was cheaper than the 16" Oneway with the outboard. I called Paul at 1Goodturn and Vicmarc is now in the process of building mine - be here in March. I look at this as the last lathe I will need. I doubt that I will ever turn anything that will use the 23 1/2" capacity, but I never thought I would go past 16". But age will catch up before I get the urge for that large a piece of wood.
I found long ago in racing, get the best you can afford and then buy what you can't - you will save money in the long run. Had I bought the Vicmarc to start with, I could have used the $2000 I spent on the Delta on tools. I spent that much anyway, but it would be another $2000 for more new toys or wood or 401k....
Best of luck in your decision, its not an easy one.
