Have a question? Ask Woody!
Missed last nights chat
Joel Hunnicutt
>I got tied up and it was late when I came up from the shop. I've got a chainsaw question. My sthil 016 (bought new in 96) got impossible to start last year. I took it to the shop and they said that the coil was broken and replaced it ($80). After I picked ip up, it will start and run but has no power at all. Took it back to the shop and they adjusted the carb but said that the carb needed replacing. Does this sound right? And if so, am I trhowing good money after bad here?
Re: Missed last nights chat
Mark Kauder, Phenix City, AL
>I will give you a synopsis of last night - if you would have posted your question:
Get a Poo lan
Buy a Husky
No way I stand by my Sthil
Yellow Rules
Orange Rules
POOOO LAAAAN never breaks
I have six chains Saws
Now way!!
You would only need one if you had a Poo Lan
(OK, I am pulling your leg a little).
Now maybe someone who really knows something about your problem will answer.
Mark
Dirty air cleaner and old gas
Russ Fairfield
>The most common causes for loss of power for a chainsaw is a dirty air cleaner and old gasoline. Do not just clean the old piece of foam in the aircleaner. Sometimes that doesn't work. Buy a new one, and mix up a fresh can of gas and oil. If you are using an off-brand of oil, switch to the Stihl oil. If that doesn't fix it, there might be something wrong with it.
Tug Fork Bob
>Another thing to check is the exhaust port,muffler, and spark arrestor screen. Two years ago my new "Poo-Lan" wouldn't rev up enough to cut poo after only a couple tanks of gas. I took off the muffler & found the spark arrestor screen clogged-cleaned it up, put it back together and it has been screaming ever since.
Bob
Mark, ter pickin' on me....
BubbaBob
>...but POO-lan still rules...
BubbaBob
Molly Winton
>Mark, your summarization skills are awesome. You're smack on, with the exception of: "I got this killer maple tree (11' long, 6' diameter) with just about every figure maple has to offer, nah, nah, nah."
>Yeah, I did not greed and envy to rear it's ugly head. I like TD and don't want a swarm of WC turners to decend upon his wood pile like locus.
Mark
Re: Mark, ter pickin' on me....
>No more than any of the others.
To be honest, my chainsaw is a 20" Poulan, starts everytime - I bought it at a Pawn shop for $80 and it works for me.
I just don't try and put it in the Husky or Sthil class.
Mark
BubbaBob
>My POO-lan started at TD's woodpile when his Sthil did not...
BubbaBob
George Van
>Joel,
I had that problem with my 021. I had to take the carburator apart and remove the fine particles that had gotten into it over 10 years. It took two times but now it runs just great.
George
Keith Tompkins
Keith Tompkins
>Hey Joel, pull the plug....fouled? you can set the mixture yourself. There is a low speed, high speed and idle screw. Read your manual or check online, and then adjust. Eventually you can HEAR when the mixture is right. Also, crankshaft seals will often fail, resulting in poor performance or no-start conditions because of a vacuum leak.
May be time for a bigger saw?
