Woodturning Tip
Woodturning Tip
Woodturning Tip
Glenn Hodges
>Someone asked for tips. Here is one I use when turning natural edge bowls. When the bowl is thin I take my air hose and blow the moisture through the side of the bowl. I place the tip of the air hose nozzle on the inside of the bowl, shoot air through the side and moisture comes out the side of the bowl. It really removes a lot of moisture from the sides of the bowl. I also use the paint stripper blower to help dry the bowl for sanding. Hope this helps.
Nashville, Georgia
Re: Woodturning Tip
Re: Woodturning Tip
>Glen
I'd be glad to put that in my folder for tips for American Woodturner if you don't mind. John
Re: Woodturning Tip
Re: Woodturning Tip
Glenn Hodges
>You are plumb welcome, as we say down here in Nashville, Georgia.
Re: Woodturning Tip
Re: Woodturning Tip
Mark Kauder, Phenix City, AL
>Glenn,
Have you ever used this method to force finish (Oil or Poly)deeper into the wood? Seems like it should work. I have used the centrifugal force of the spinning bowl - put a heavy coat inside the bowl, and then spin the bowl up. It is also a great way to find open glue joints in segmented bowl - DAMHIKT.
Just a thought.
Mark
Re: Woodturning Tip
P.S.
>I also know if you put a bowl that does not have a fully cured finish on the outside on your vacuum chuck, it can pull finish through the bowl.
Mark
Re: Woodturning Tip
Re: Woodturning Tip
Glenn Hodges
>Mark, I never have, but it might be a technique worth trying. The reason I probably have never tried it was I was afraid it might get oil on the glue on my eyeglasses....he, he....
Re: Woodturning Tip
Re: Woodturning Tip
JamieDonaldson
>Glen-I have an old camera repairman's tip for the glasses-lightly mist a clean cotton cloth with ArmorAll, then clean the glasses, camera lenses,crystal collection-anything shiny.It does wonders as a glass or plastic cleaner, and will keep the CA dots from sticking quite so well the next time!I carry such a cloth when I visit my turned pieces in a gallery-takes the fingerprints right off and renews the shine.
Re: Woodturning Tip
Re: Woodturning Tip
Glenn Hodges
>Thanks Jammie, maybe that's what I need to keep in my shop. I will get some of that, appreciate the tip.
Nashville, Georgia
