200+ woodworking book reviews
Dumb Question?
Dumb Question?
Dumb Question?
Glenn Hodges
>What if I put my eyeglasses in a quart of acetone and soaked them over night? Would this remove the CA glue from the lens?
Re: Dumb Question?
Re: Dumb Question?
Bert Smith
>Don't do it if they are plastic type lenses, like mine were...:-) I don't know about glass lenses.
Bert
Re: Dumb Question?
Re: Dumb Question?
RevDoug
>Only if they are glass lenses, you should be able to get the glue off with some acetone on a rag. If your lenses are plastic, sorry, you're out of luck.
Turn 'em round,
RevDoug
Re: Dumb Question?
Re: Dumb Question?
George Troy
>Debonder does work and I have used it on my plastic lenses. It works fast and did they job for me. Of course as they say use at your own risk. I don't think a soak is necessary. GT
Re: Dumb Question?
Re: Dumb Question?
Brian MacDonald - Olympia, Wa
>One thing that would concern me is the coatings on the lenses. Anti-glare, scratch-resistance, etc might be removed as well as the CA.
Re: Dumb Question?
Re: Dumb Question?
Greg
>Glenn,
RIGHT before you throw your glasses away, remember that micromesh is used to polish glass, so you could literally sand the CA off which will scratch the glass, and use the MM to polish the glass back out. Again, definitely a last ditch effort kind of thing, though.
Re: Dumb Question?
Re: Dumb Question?
Glenn Hodges
>Thanks everyone, I have even thought about using the white part of the Beal Buffing System to try and remove the glue and scratches from the plastic glasses. I will order some of the debonder.
Half Blind in Nashville, Georgia
Re: Dumb Question?
Re: Dumb Question?
Jim Pugh in Ohio
>You will find that acetone and a q-tip or similar will remove the CA glue. I have plastic coated lenses and was reluctant to use the acetone so took them to my optician - who used acetone.
