Portable Stand for Mini-Lathe - Any experience?
Rob W.
>If Jet/WMH delivers stock to Tool Crib as scheduled, I should have a new Jet-mini here by the end of this week, or early next... I'm looking forward to having another fun toy, especially a smaller lathe to teach my 6 year old son how to turn (...he's been itching to pick up a gouge for months since I got the new Jet 1642 back in July!). I would like to build (or buy) a portable stand (not unlike stands/supports for miter saws) for the Jet Mini-lathe (that I will modify with the DC variable speed motor from Vega) so that I can easily transport the lathe to meetings and teaching sessions away from my shop. Hopefully this setup will fit in the back of my Explorer. Not wanting to re-invent the wheel, I'd like to ask the turning cognoscenti if anyone has built a collapsible lathe stand for a mini-lathe that gives good support, yet has wheels/rollers and folds to make transport easy. I am thinking about buying an inexpensive mitersaw stand, but I'd like to know if anyone has already gone down this road and can offer some ideas. Perhaps clubs have portable stands for their group's lathes? Does anyone have some experience with this, or can offer some advice? Thanks! Rob Wallace in Iowa
Re: Portable Stand for Mini-Lathe - Any experience?
Greg
>Rob,
I've used a Black and Decker "Workmate", and it's worked fine. It works well as long as you're not turning anything heavy or significantly out of balance.
Re: Portable Stand for Mini-Lathe - Any experience *LINK*
Edward
>I have used this miter saw stand made by Delta to support several different mini lathes. I took off the roller out-riggers and screwed a piece of MDF to the top to sit the lathe on. The whole rig folds up and rolls around on the big wheels, very easily.
Edward
http://www.deltamachinery.com/index.asp?e=139&p=4876
Motor - where ?
Fred L. - North Carolina
>I am mounting my Vega motor UNDER the lathe. The motor is easily reversible. Universal motors, unlike the brushless magnetic ones, turn in one direction only. I reversed mine to be able to mount it under the lathe, in a cabinet that I am working on. This makes the whole setup about 12" shorter. The cabinet will also provide some storage, and add to the weight.
The Vega motor is open frame and needs an enclosure. It should also have a fan.
Re: Motor - where ?
Mark Kauder, Phenix City, AL
>Rob,
Fred is right, adding the VS Vega motor complicates the situation. If you intend to use the motors as I mounted it in the orginal posting, and want to make it portable, you should mount the lathe and motor an a piece of good 3/4" plywood, and then you can mount that on the stand.
Mark
Re: Motor - where ?
Rob W.
>Mark: Thanks for the follow-up! I have already cut oak veneer plywood for the box that will be beneath the Jet Mini-Lathe, and plan on mounting it under the lathe bed as you and Fred suggest. (I was actuallly going to e-mail Fred about what his source was for the new belt required for the added distance between spindle & shaft, and ordering specs for the belts.) I am following the two suggested electronic mods to the circuit board (I'm a ham operator of 25+ years so this is a no-brainer), am adding a direction reversal switch, and taking the conversion even further; I will add a power control relay and pushbutton stop-start. All of this will be contained in a box under the lathe (along with a small cooling "muffin" fan blowing through added heatsink fins already attached with thermal transfer compound to the aluminum back side of the circuit board heatsink). The bottom of the box will have extended flanges on each end so that I can quickly bolt it on and off the portable table (whatever I actually decide to do). This will be a sweet little portable lathe that I hope to be able to take to meetings and give turning classes in "remote" locations (i.e. away from my shop). I want to thank you for posting such an excellent review of your conversion and modification of the Jet mini-lathe motor to DC Variable speed! The present low price of the Jet mini and the availablity of the Vega motor was inspiring enough for me to drop the cash needed to do this project. I suspect many others are also thankful for your efforts. Best regards, Rob Wallace
Re: Motor - where ?
>It is a good idea to get the motor first.
After I received the motor, I bought a new motor pulley from Jet, and a 40" belt from Aarubco Rubber. Their belt prices are very low, the 40" belt was less than $8.
The motor is open frame and needs to be cooled. That is why I decided to mount it under the lathe. Mounting it where the original motor is would not leave room for a shroud and fan.
FredL
Re: Motor - where ?
>Feel free to email me anytime.
73s
FredL
Re: Motor - where ?
>Rob,
Thanks for the compliments. It sounds like you have all the technical expertise required to make it a first rate operation.
Feel free to email, but Woodturning in the Subject like so you don't get deleted as a spam.
Mark
