Turnings 101 - What do you think?
Ron Sardo from PA
>Well, here I am baring my soul so to speak. I've been turning since August, I really would like to know what I've done wrong or right. So please be critical, I feel this is a good way to learn. Don't worry I have a thick skin, I won't go off the deep end.
This is the cherry bowl that started SWMBO talking about bookshelves and lathes. It measures 9.5" x 3" and 1/2" thick. Wet sanded with watco to 400 and wax with Minwax. Bill - this is the bowl I rough out at your place.
Cherry bowl 6"x 2.5" 1/4" thick, wet sanded to 320 with watco and finished with Johnson's wax
Cherry Bowl 6" x 3.5" 3/8" thick, wet sanded to 1500, burnished with brown paper, finished with lacquer and buffed out with automotive rubbing and polishing compounds, waxed with minwax.
7" x 4"x 3/8" cherry bowl, watco and wax
Cherry Candy Dish 6" wide and 3" tall. Wacto and wax. Even though I used the longest focal length on my digital camara the top still looks warped. It's not. Anyway I zapped this bowl a dozen times in the microwave to dry out the green wood. Wet sanded with watco to 400, dark shellac, varnish and John's paste wax
When I grabed this rough out shape there was a crack (on the backside). I expoyed it and decided to take Russ's idea "Turn something thin so you know you can do it then go back to thicker bowls" (or something like that). I decide to take his advice and since I had nothing to lose I'd give it a try. By the time I finished turning this turned out to be 1/16" thick. With the lid (purpleheart) it measures 3"x3". Sanded to 600, then rubbing and polishing compounds again, lacquer, polishing compound then waxed.
I don't know what the heck I had in mind with this one. When I grabed this roughed out shape and looked at it I thought it was ugly, so I decided to experiment. That same day Wally had posted a beaded bowl, so I thought I'd give it a try. I was kind of pleased with it's look and decided to try making a lid for it. The first one had a sloppy fit but happened to fit perfectly on the box above so I decided to make a second lid for this one. I think it looks like a bee hive.
One day Xmas shop with the wife she was looking at some crystal candle stick holders. She mentioned that they where either to short or to tall. I asked her what size she liked and later I started making these for her. They are not crystal but she is happy with them. This was the first time I tried to make two exactly the same turning. Not as easy as I thought. Even though the photo doesn't show it, they are both the same height. 4" tall x 2.5" wide. Cherry and walnut, lacquer finish
Cherry and walnut vases. the one on the left has a dark shellac and varnish finish the one on the right has watco. both are waxed and stand about 6"tall. There is a glass insert to hold water. I drilled the hole a little deeper in these and expoyed a lead sinker to the bottom. I was afraid thay might be top heavy. With the extra weight they have a really nice feel to them. Over the holidays every female vistor who came to visit wanted one of these. Thay all prefered the one that was varnished.
