Scotch Brite
Scotch Brite
Scotch Brite
Gary Bills in NC
>Anyone know the grit equivalant of Scotch Brite, Beartex, and Fibral? It would be nice to know when to go from a particular grit sand paper to Scotch Brite.
Re: Scotch Brite
Re: Scotch Brite
TDaniel
>Gary, I do not use steel wool or one of these fibre alternatives to replace sandpaper of any grit. I use the wool on finish between coats. The fine (0000) works best between coats of oil. This is followed be a cotton flannel dusting. I am impressed by the Fibral wool.
Re: Scotch Brite
Re: Scotch Brite
jim moy
>according to 3m, the red pad is close to 320 grit and the grey is close to 600 grit.
i own a body shop and we use these pads all the time (got cases of this stuff).
Re: Scotch Brite
Re: Scotch Brite
JamieDonaldson
>The gray Scotchbrite is equalivant of 0000 steel wool without a lot of its problems,like rusting in green wood and sticking in your fingers.I use it a for a lot of other tasks,such as cleaning lathe bed ways with WD-40.
Re: Scotch Brite
What is the GREEN equivalent?
Clem Wixted Jonesboro, AR
Re: Scotch Brite
Re: Scotch Brite *LINK*
Mike-in-Michigan(Richland, that is)
>See the link below:
PDF File w/All Equiv Info you need
Re: Scotch Brite
Thx Mike; good info
TDaniel
Re: Scotch Brite
Thanks for the link ! Where do I buy ?
Fred L. - North Carolina
Re: Scotch Brite
Re: Scotch Brite
Russ Fairfield
>A comparison of grits and equivalents doesn't necessarily mean that one can replace the other. There is always "the rest of the story".
The non-woven arbasive pads, sandpaper, and steel wool all abrade the wood differently and there is a difference in shape of the scratches in the "scratch pattern" that they leave behind on the surface of the wood.
A recent comparison by Jeff Jewett concluded that the fabrics were best suited for sanding between coats, and the softer scratches from steel wool were still the best for cutting back on the gloss of the final coat.
Re: Scotch Brite
Re: Woodworkers' Supply *LINK*
>Woodworkers' Supply
White (extra fine) 850-518
gray (fine) 850-532
maroon (medium) 850-546
They do not state who is the manufacturer of these pads.
Re: Scotch Brite
Thanks, Mike
Re: Scotch Brite
Re: What is the GREEN equivalent?
>I read somewhere that the green stuff is equivalent to 0 steel wool. Of course, since there is more than one manufacturer, and no standardization for colors, YMMV.
Re: Scotch Brite
A BIG thanks for this link
Bill Tindall, E. TN
>I suggest this information be preserved in the Articles section. Would you submit it....
I tried unsuccessfully to get this information from 3M for some time. One 3M tech rep even told me what a good idea it would be to have it!
