Dying and sanding
Dying and sanding
Dying and sanding
sean Troy
>Hey all, today I will be applying some aniline dye to a vase I,ve turned. This is my first attemp. How far should I go with sanding to get the best results. I'll be mixing the dye with water. Thanks, Sean
Re: Dying and sanding
Fred L. - North Carolina
>Sean:
With water based anything, I have sanded to 600 and applied the color. When dry I sand 600 again because it raises the grain a bit. If the dye has penetrated at all, this sanding will not affect the color. Then I go through the finer grits.
I have used an air brush at times to apply color.
FredL
Greg
>Sean,
I've only used analine dye on pens, not on vases. With that said, I sand to 600, apply the dye, let it dry, and very lightly sand with the grain only, lathe off. I mainly dye maples - bird's eye, curly. I've had very good luck with this technique. However, I do a CA finish, which of course leaves a glassy, glossy surface and doesn't cause a problem with the dye. I'm not sure what type of finish you're going to use over your dye, though.
sean Troy
>I will probably use a gloss lacquer and then buff. Thanks, Sean
Hey Greg!
Dominic Greco in Richboro PA
>Greg,
Have you gotten around to turning anything from your "trivia contest" wood?
See ya around,
Dominic
Re: Hey Greg!
Greg
>Not yet, though I hope to do the "main" piece possibly this weekend. I have a group of bowls I'm about to finish, and then a couple of pens, then that one. I didn't want to blow it for lack of time, or experience!
Ron Sardo in PA
>With water based dyes you need to raise the grain FIRST with clean distilled water. Tap water may have minerials which can stain the wood. You should also mix your dyes with the same type of water.
After you raised the grain and the wood has dried, lightly sand, you are only trying to remove the the raised grain. if you sand to heavy the grain will raise when you apply the dyes and you have defeated the purpose.
NOW apply the dye. Sand again. If you are appling more than one color dye and you sanded too heavy you may need to raise the grain again and sand back.
Now apply your finish.
As always, you should test this procedure first on scrap, not only to get the feel of how your wood will react but also to test the colors and practice your techique.
Re: Dying and sanding *LINK*
Russ Fairfield
>Check the article in the link. It mat be helpful.
Coloring with Analine Dyes
Ron Sardo in PA
>That is the best article I've read on this subject - Thanks
